01 7.3 Need Help! - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Decaturforlife01
post #1 of 8 Old 07-10-2019, 07:32 AM Thread Starter
Quoted: 2 Post(s)
Garage
01 7.3 Need Help!
My 7.3 is having a few issues. The turn signals do not work(hazards does). Speedometer doesn't work (RPM does). No cruise control and the overdrive light is flashing. I have check all fuses. Anyone seen this before or know where to start? Got a P0603 code.
Sprcrw01 is offline
post #2 of 8 Old 07-10-2019, 08:59 AM
DesertDiesel's Avatar
Quoted: 66 Post(s)
I'll take a crack at one of the issues. You have a vehicle speed sensor or VSS on top of the rear differential. Replace that and you should be good to go. Your symptoms support this i.e. no speedo, OD flashing and no cruise control. I would go with a Motorcraft and make sure you solder and heat shrink the new pigtail.
DesertDiesel is offline
post #3 of 8 Old 07-10-2019, 11:51 AM
SuperCrutyPS's Avatar
Quoted: 598 Post(s)
Garage
This is what the code is:
P0603 Internal Control Module KAM Error
Check to see if there is a fuse for that?
Darryl | Owner/Operator
Truck | 2001 F350 CCLB
5th Wheel |
Proud Veteran | US Navy - '76-'80 - Petty Officer 2nd Class (E5)
SuperCrutyPS is offline
post #4 of 8 Old 07-11-2019, 07:13 PM
Double check the fuse diagram. I had the same problem when I brought my first 7.3. When i brought the truck the last person had a jump wire for the ac compressor which made everything work. It took me 2 months to find out that the fuse box wasn’t making a good connection to the fuse.
Sprcrw01 likes this.
Decaturforlife01 is offline
post #5 of 8 Old 07-12-2019, 06:51 PM Thread Starter
Quoted: 2 Post(s)
Garage
Changed the VSS today no help.....Decaturforlife01 ----That sounds like what happened to mine. What did you do to fix your issue?
Sprcrw01 is offline
post #6 of 8 Old 07-13-2019, 05:08 PM
greenskeeper's Avatar
Quoted: 291 Post(s)
KAM error is common (and nothing wrong) due to battery disconnect or chip installed
greenskeeper is offline
post #7 of 8 Old 07-13-2019, 05:09 PM
Quoted: 291 Post(s)
harness chaffing?
GEM module (if applicable) faulty?
post #8 of 8 Old 07-14-2019, 08:23 AM Thread Starter
Quoted: 2 Post(s)
Garage
Thanks for help guys!!!
Sprcrw01 is offline
