Trans Flange Dowel Pins Snapped Off - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-09-2019, 01:59 PM Thread Starter
Quoted: 5 Post(s)
Hello all. The dowel pins for the trans flange are snapped off in the engine and they are hardened throughout so drilling them out is impossible. How do I go about removing those or should I grind them out with something like a Dremel and carbide burr?
Early 99 7.3 F550 4x4, 6 Shift, 11 Foot Flat Bed Dump
2002 F250 Crew 7.3, Daily Driver, some stuff done to it.
2000 F250 Crew Gasser
1999 F250 Gasser
7.3early99F550 is offline
post #2 of 5 Old 07-09-2019, 03:53 PM
Quoted: 418 Post(s)
Feedback Score: 3 reviews
Let 'em Soak in penetrant and then, if you can, Weld something smaller than they are onto the broken surface. The Heat Shock of welding to them often does wonders
NoRalPh is online now
post #3 of 5 Old 07-10-2019, 05:31 AM Thread Starter
Quoted: 5 Post(s)
The reason they broke off is from use of a acetylene torch and 3 vise grips trying to spin it loose. They did move at first but gotten tighter we kept twisting them. I have read on another forum how people have drilled out the other side and used a grease gun to push the pin out. Will be trying that today.
1999 F250 Gasser
post #4 of 5 Old 07-11-2019, 02:24 PM
Why Not Drill a Hole on the reverse Side and use a Punch and Knock them out!
Dennis Darley is offline
post #5 of 5 Old 07-12-2019, 04:11 AM Thread Starter
Quoted: 5 Post(s)
Dennis, that is exactly what I did. Drilled the cast iron up to 21/64" hole and pushed the pin out with a punch. if it didn't come out with this method, that size hole can be tapped for a 1/8" npt zerk and used a grease gun to push it out hydraulically.
1999 F250 Gasser
