Crank no start - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-23-2019, 04:37 PM Thread Starter
Crank no start
I have a 1999 F250 super duty automatic has 220k miles.
I was driving down the freeway and my truck losess power and dies my WTS light came on my water in fuel bowl and my SES light. I tried to start it back up when I pulled over but this time my WTS light would even come on it. But the truck would just crank no start Thanks in advance.
cvenny8 is offline
post #2 of 6 Old 05-23-2019, 08:52 PM
Quoted: 2 Post(s)
Any chance you have something connected to the OBD2 port? This happens to me when I try to connect something there. You can also pull the drain valve to try and dump some fuel and see if there's actually water in your fuel.
climbermaniac92 is offline
post #3 of 6 Old 05-24-2019, 05:56 AM
Quoted: 405 Post(s)
Feedback Score: 3 reviews
Don't even bother trying to start until you get the WTS light back on (shows the PCM is up & running and with out the PCM running you're Never going to start).
In the Vast majority of cases, this is a blow fuse somewhere that supplies power to the PCM (and sometimes other things too like the Fuel Heater Element). Go over All your fuses, especially the ones associated with the PCM (look in the Owners Manual). Don't just "glance" at them, you can be fooled, use a light or meter to check Both sides of each fuse (if you find that heater element fuse is blown, be sure to unplug it from the bottom of the fuel bowl or it will just blow again because it's starting to short)
Next, if all the fuses are good, go to the big, square, connector over the dr side valve cover (it connects the engine's electrics) and Open it to disconnect all engine sensors. If the WTS returns with it unplugged then you have a sensor that's drawing-down the 5v reference line the PCM uses. You can find that sensor by unplugging them one-at-a-time (with that connector plugged back in) to find the bad one. Start with the EBP sensor, it's most often the problem.
NoRalPh is offline
post #4 of 6 Old 05-24-2019, 05:42 PM Thread Starter
I’ve looked over all my fuses and there good. I think it could be the three square plug in behind the pcm. Cause every time I play with them they WTS light comes back on and I’m able to start my truck
cvenny8 is offline
post #5 of 6 Old 05-25-2019, 05:16 PM Thread Starter
I think I need a new pcm ?
cvenny8 is offline
post #6 of 6 Old 06-09-2019, 11:40 PM
Quoted: 25 Post(s)
Sounds like the wiring if jiggling it works. Did you clean it and add some dielectric grease? Can you engineer the connection tighter with some zip ties?
Sent from my Nexus 6P using Tapatalk
guitarnut is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
95 7.3 crank won’t start, starts with ether, dies at idle Owen Daniel 94-98 7.3L Problem Forum 3 07-23-2018 05:21 AM
2001 7.3 Crank No Start, No WTS Light, No Fuel??? GraysonM 99-03 7.3L General Discussion 6 03-29-2018 03:39 PM
05 6.0 starts cold, crank no start when hot waistline00 6.0 Motor problems 68 08-07-2017 01:58 PM
Will start when cold, No Crank when hot jstofan 6.0 Motor problems 1 07-28-2017 09:14 AM
Feel like i've been taken for a ride. Don't know what to do. 1950Allis General 6.0L Discussion 264 05-01-2017 04:28 AM
