7.3 rough idle. Help - Ford Powerstroke Diesel Forum
post #1 of 1 Old 04-04-2019, 09:07 PM Thread Starter
Have a 2003 7.3 with 190,000 miles. Truck starts up great. Even when its chilly out. Fires right up. Runs good for about 30 seconds then starts to miss. Blows blue/white smoke. Not really thick but enough to be an issue. Has blow by. Took the oil fill cap off and turned it over. Cap dances around on top a few times then will fall off but cant tell if it's from the pressure or the fact that the engine is shaking.
UVCH and valve cover gaskets are new.
What should I start with?
Thanks
Lazytitan57 is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
6.0 Loss of power dies rough idle 6.0 Medic 6.0L Problems Forum 5 02-03-2019 08:01 PM
Rough idle??? markm7273 94-98 7.3L General Powerstroke Discussion 5 10-20-2018 08:07 PM
Intermittent rough idle with video. Landcruisin60 6.4 Motor Problems 7 03-25-2018 01:38 PM
rough idle at first then smooths out cbgaloot 6.0 Motor problems 0 11-21-2016 06:22 AM
Intermittent Rough Idle - Dead EGR Valve? attila the hun 6.0 Motor problems 36 11-11-2016 12:53 AM
