Turbo clamp stuck - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 14 Old 03-24-2019, 04:13 PM Thread Starter
DesertDiesel's Avatar
Quoted: 69 Post(s)
Turbo clamp stuck
Thanks for your help everyone. I'm doing a turbo rebuild and the clamp at the back of the turbo is stuck, I can't remove the turbo until it's off, obviously. Not being able to see anything back there, are there any tricks to the trade to get it off sight unseen?
Thanks!
Jared
DesertDiesel is offline
post #2 of 14 Old 03-24-2019, 04:46 PM
Mike Gs's Avatar
Quoted: 103 Post(s)
I had to torch the nut and replace the clamp.
Mike Gs is offline
post #3 of 14 Old 03-24-2019, 04:59 PM
hansel's Avatar
Quoted: 359 Post(s)
Soak it with PB blaster, let it sit for awhile, then soak it some more. Then use a long pry bar and it should pop right off.
PS. Order a new clamp
jokester00 likes this.
hansel is offline
post #4 of 14 Old 03-24-2019, 05:09 PM Thread Starter
Quoted: 69 Post(s)
Good suggestion. I soaked it and finally got it. F'in perseverance. Got it off! Thanks
hansel likes this.
post #5 of 14 Old 03-24-2019, 05:17 PM
hansel's Avatar
Quoted: 359 Post(s)
Might I suggest replacing the up pipes if you already haven't, and just wait the fun is only begun, the fun part is putting that clamp back on
Got Dirt? and Fauxton like this.
hansel is offline
post #6 of 14 Old 03-24-2019, 07:34 PM Thread Starter
Quoted: 69 Post(s)
I'll let you know but at first thought couldn't be worse than getting it off. What a b**tch!
post #7 of 14 Old 03-24-2019, 08:24 PM Thread Starter
Quoted: 69 Post(s)
Ok, you got me...how in the hell do you get that F'in thing back on??? Do i need to buy a new one? Damn!
post #8 of 14 Old 03-24-2019, 08:34 PM
I can't remember exactly how I did it but I do know that it involved a few pry bars. Im not too mechanically inclined so it took me probably an hour to get it on but getting a new one is no easier!
Sent from my Pixel using Tapatalk
Fauxton is offline
The Following 2 Users Say Thank You to Fauxton For This Useful Post:
DesertDiesel (03-25-2019)
post #9 of 14 Old 03-25-2019, 06:33 AM
hansel's Avatar
Quoted: 359 Post(s)
If the clamp isn't damaged then you can get away with using it again. If in doubt replace it, putting it back on it's a feel thing because you can't see what you are doing. Before you put the turbo back in place the clamp over the collector, and have it where the bolt is not locked into the clamp, the T end of the bolt.
hansel is offline
post #10 of 14 Old 03-25-2019, 08:16 AM Thread Starter
Quoted: 69 Post(s)
Thanks. I had to leave it undone last night. Will go at it with a fresh head today. Glad I did too because I think I bent the pipe backward slightly trying to get the turbo out. This may explain why I'm having so much difficulty. I'll let you know what I had to do to get it on. I'm thinking maybe a pry bar or tilt the turbo back a little, get the clamp on then fasten the turbo down.
JARED
Similar Threads
Thread Thread Starter Forum Replies Last Post
Does oil leave the center turbo housing? Diverter valve leak? bahadur General 6.0L Discussion 0 12-13-2017 10:24 PM
P0299 Underboost-Going to rebuild Turbo but which parts? thaemcee2 6.0 Motor problems 14 08-17-2017 09:25 AM
Turbo Surging..please help thaemcee2 6.0 Motor problems 3 05-06-2017 09:17 PM
Up-pipe install and turbo heat shield quiestions.. jemorgan3 General 6.0L Discussion 3 03-27-2017 04:32 AM
Custom single turbo strokinginstyle6.4 6.4L Performance Parts Discussion 5 08-26-2016 04:48 AM
