Hole in my head - Page 3 - Ford Powerstroke Diesel Forum
 1Likes
post #21 of 22 Old 04-05-2019, 03:26 PM Thread Starter
Quoted: 5 Post(s)
Originally Posted by 00t444e View Post
I almost forgot about this thread. The head from the link I posted seemed to be machined well and already had new injector cups in it. I used Felpro head gaskets and bolts, he has been driving it for a couple of weeks and the only problem was one of the fuel banjo bolt orings on the back of the head was bad and it caused a fuel leak after a couple weeks, so if you get a head from them pull the banjo bolts and replace the orings before you install it.
I went with the Ford heads, figured I couldn't go wrong with Ford parts. Still working on it, did some cleanup in the engine compartment while the engine was out. Did you change the heads in the frame, or did you pull the engine?
Roger_F is offline
post #22 of 22 Old 04-05-2019, 03:33 PM
00t444e's Avatar
Quoted: 622 Post(s)
I changed it with the engine in.
00 f250 ext. cab, lb, 4x4, 170,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, KC 300x 63/73/.84 turbo, PHP Hydra, Riff Raff frx,, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, Edge CS2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
My Cab-On Head Gasket Project...*PICS* iqraceworks General 6.0L Discussion 79 02-13-2020 12:10 PM
Yet another head gasket thread JPGale 6.0L Problems Forum 60 06-02-2019 09:55 AM
6.0 Driver side head removal.. grysquirl General 6.0L Discussion 10 09-04-2018 01:52 PM
Lifting Head? Resealing? Windgineer 6.0 Motor problems 17 04-19-2018 04:07 PM
Head Reinstall ?s hummer010 General 6.0L Discussion 1 11-04-2016 11:38 PM
