Losing power rapidly going up hills.. - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 13 Old 01-15-2019, 09:34 AM Thread Starter
Hello, I have a 2001 f250 7.3 that I recently just replaced the uppipes in as well as the turbo pedistal O rings, this all fixed the issues I was having but she runs good up until I try to take it up a hill and the she boggs down and will drop from 120 kmhr to 60 rapidly. Just seeing what ideas are our there.
Fordnut714 is offline
post #2 of 13 Old 01-15-2019, 09:45 AM
cmunsell's Avatar
Quoted: 4 Post(s)
complete shot in the dark but had similar issue - have you replaced the fuel filter?
cmunsell is offline
post #3 of 13 Old 01-15-2019, 12:13 PM
Mike Gs's Avatar
Quoted: 103 Post(s)
My 99 did this- trans was going. Truck sat 3.5 years before doing a bunch of work similar to your list. Test rides went well- until some big long hills on the way home. No power. Seemed ok on level ground but as soon as I had it under any load, it would bog down. I am sure it can be other things but mine was fixed with a rebuilt trans installed.
Mike Gs is offline
post #4 of 13 Old 01-15-2019, 02:19 PM
Is it throwing any diagnostic codes?
tcpip95 is offline
post #5 of 13 Old 01-15-2019, 03:30 PM
JustinOOO9's Avatar
Quoted: 1679 Post(s)
Garage
Feedback Score: 3 reviews
wrap the up pipe joints in tin foil. I bet you have a leak. they are nearly impossible to detect visually and you just did them. Also what are the egts/boost/speed when going up the hill?
one thing you can do and it will help a ton when the issue is resolved is unplug the red vac hose end on the brass cupcake on the turbo housing. Then plug the red hose end near where the other end is on a plastic nipple. You'll see 3+more boost psi on hills. Most waste gates need to be tightened but you can just remove te red tube. It was infamously called the "red tube mod"
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is offline
post #6 of 13 Old 01-15-2019, 09:32 PM Thread Starter
I threw it on Auto Enginuity and no codes came up. The tranny isn't slipping but there is a substantial lag in gear change when punching it. haven't checked the fuel filter yet.
post #7 of 13 Old 01-15-2019, 09:43 PM
hansel's Avatar
Quoted: 383 Post(s)
Is it blowing any smoke?? and if so what color is it??
2001 7.3L CCSRW 4X4
2003 7.3L CCDRW
S&B intake, 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission. Edge SCT2
PHP Hydra chip's
2015 Heartland Prowler
hansel is offline
post #8 of 13 Old 01-16-2019, 08:13 AM Thread Starter
Not blowing any kind of smoke what so ever.
post #9 of 13 Old 01-16-2019, 09:53 AM
Quoted: 467 Post(s)
No codes and can't maintain power under high loads?
I liked the Fuel Filter suggestion...
Hydro likes this.
NoRalPh is offline
post #10 of 13 Old 01-16-2019, 07:33 PM
Corey@CNCFAB's Avatar
Quoted: 1459 Post(s)
Feedback Score: 4 reviews
Sounds like your a good candidate for the hutch mod.
www.cncfab.us
[SIZE="3"]For all your ford powerstroke needs. If you dont see what you are looking for on the website, please use the contact page and shoot us a message or
Part numbers will help alot too if they are not on our site.
