Low oil pressure 100 miles after rebuild - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-07-2018, 02:22 PM Thread Starter
Quoted: 2 Post(s)
Hey guys, need some ideas...
I have a early 99 with 275k miles, little over 100 miles since I did a full rebuild. ..machine shop, new lpop, rebuilt injectors +40pistona new everything.. etc....
Fired right up and has been running great minus the turbo rear seal/housing that i just fixed..
At first the oil Guage would read normal at idle and drop when accelerated. Now, no oil pressure at idle but after 1500rpm it comes up.. I did put it on a manual Guage via top of hpop and was getting around 5-7psi at idle and 20+ @ 1500rpm..
I drained and inspected oil, minimal metal as to be expected after rebuild, scoped oil pan and could not find anything in there but could not see pickup screen/tube. Took it to a very reputable diesel shop and they could not figure it out... any ideas on where to go from here, I really do not want to pull this engine again.. thanks in advance!!
rpetty5555 is offline
post #2 of 3 Old 09-08-2018, 05:08 AM
Quoted: 46 Post(s)
Have you checked the oil pressure relief valve?
97 F350 XL std cab, zf5, srw (converted), 4wd, 3.55s, stock wheels/tires & rebuilt 9.18
2 Donaldsons, 3" dp, ACs, T500, HV LPOP, Hydra w/PHP, DIY 60 gl tank w/6 gl sump, eFuel/Cat filters, Aeromotive RR, Auber instruments, 140v IDM, KC 300X 63/70/84, boost fooler, RiffRaff bellowed up pipes, 6.0 IC, 3" plenums w/RiffRaff inserts & SB 425HD
MeTo is offline
post #3 of 3 Old 09-08-2018, 05:28 AM Thread Starter
Quoted: 2 Post(s)
No, I have read several other forums and that seems to be a issue. But when I just changed my oil I realized that the oil cooler assembly must come out to do that. .. I will check that this weekend...
Thank you..
