Help chasing an AC problem - Page 2 - Ford Powerstroke Diesel Forum
post #11 of 13 Old 06-19-2018, 04:11 PM
PowerStrokeFoolish's Avatar
It could be the orifice tube, put that would cause the high side pressure to be really high, which means there is a restriction in the system. That is also a remove the refrigerant, fix, recharge item. Changing the tube is fairly simple but if you do not know how or have the equipment to remove and replace the refrigerant you will need some help.
The ac system is not that complicated but most people get all freaked out over it because the do not understand how it works. Do a little research on how the system works and watch some YouTube vids and you may surprise yourself when it comes to fixing your ac.
PowerStrokeFoolish is offline
post #12 of 13 Old 06-21-2018, 04:32 PM Thread Starter
Locke6169's Avatar
Quoted: 3 Post(s)
Originally Posted by DarthF250 View Post
Have you cleaned your condenser? Could be caked with dirt and debris.
You checked fuse 24 that handles the door actuator? Should be a 10 amp.
Fuse was good but I think I found the problem
Originally Posted by Durapig Eater View Post
Again a bad vacuum leak somewhere else in the system will cause a default to defrost. If it defaults to defrost when you put it 4x4 then you have a leak. This will NOT cause hot/warm air from the vents because the blend door is electronic.
It will cause your MAX AC not to function properly.
I had an 03 where the refresh/recirculate door arm was busted. From the passenger floor board reach way up to the firewall and the refresh door is hinged horizontally behind a plastic grid. Then a vacuum actuator and a bomarang looking plastic armature connected to the door. I changed mine without pulling anything apart dash wise, but it is a one eye closed, hold your teeth just right, work by faith no by sight sort of thing.
Hopefully it will cool down by Thanksgiving so you can fiddle around with it.
Or chain a generator down in the bed and put a window ac unit through the rear sliding window.....
I put the truck in 4x4 with the AC on and it did not revert to defrost.......I think I may however have found my issue. I pulled the blend actuator and a piece of broken plastic came out with it, so I think the hole where the actuator goes in is broke. I took the cover off of the heater core and stuck my hand behind it and was able to push closed what I suspect was the blend door. When I did this the air turned cold. I put the cover back on and the actuator back in and I now have cold air. Im guessing that when winter comes I will have this same issue with heat if I do not replace the door assembly....but I will cross that bridge later in the fall
1999 F350
-4" Turbo back exhaust
-Garrett GTP38r Turbo
-Upgraded Early 99 Single Shot Injectors
-ARP Head Studs
-AFE Intake
-RiffRaff Up Pipe Kit
Locke6169 is offline
post #13 of 13 Old 06-21-2018, 06:43 PM
Durapig Eater's Avatar
Quoted: 163 Post(s)
Glad you got it figured out
Personal Truck/Heavy Hauler 12 F350 XL 4x4 DRW CCLB 3.73 LSD Black
Shop built headache rack, tie downs, and knock down ladder rack, Tread plate bed mat, Airbags, Cheapo light bar, bug screen on the grill, transfer tank w/ pump and racor filter, shimmed overloads, CTS, X4 Tyrant tunes, Full Dirty
Originally Posted by nighthawk285 View Post
Durapig you win the internets today hahahaha
Just because your not paranoid doesn't mean their not out to get you...
Durapig Eater is offline
