Bad battery's? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-25-2017, 06:06 PM Thread Starter
Strokininthe208's Avatar
Quoted: 29 Post(s)
Bad battery's?
It starting to get cold and my truck is cranking slowly. The voltage is dropping to around 8.9 volts cranking. Sound like battery's are bad?
Sent from my SAMSUNG-SM-G890A using Tapatalk
Strokininthe208 is offline
post #2 of 7 Old 09-26-2017, 05:20 AM
Heavy_GD's Avatar
Quoted: 3119 Post(s)
Garage
Feedback Score: 4 reviews
I hope that is a statement and not a question.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #3 of 7 Old 09-26-2017, 07:23 AM Thread Starter
Quoted: 29 Post(s)
No a question. I didn't know what it should be with the glow plugs still sucking juice.
post #4 of 7 Old 09-26-2017, 07:27 AM
Heavy_GD's Avatar
Garage
Gotcha, 11Vs is the norm with GPs firing.
GD
Heavy_GD is offline
post #5 of 7 Old 09-26-2017, 03:22 PM Thread Starter
Quoted: 29 Post(s)
Ok guess I should have worded my question differently. I know that key on not cranking voltage is 11.3. Cranking with glows plugs going drops to 8.9. Your saying it should maintain 11 volts?
post #6 of 7 Old 09-26-2017, 03:41 PM
Quoted: 437 Post(s)
Feedback Score: 3 reviews
The GPs have a significant battery load (up to @150A) and the reason we have Two batteries. So, YES, 8.9v is way too low and good batteries will run the plugs AND crank the engine over at the same time maintaining 10+v.
If they're over 5yrs old and doing this I would just replace them Both (should always be done in pairs). If they're newer than that then I would have them Load Tested, at a High Rate (not one of those dinky 100A testers the parts stores use, out Big batteries need to be loaded to @300A to properly test them).
So charge them up fully and have them individually tested at some place with the right tester or maybe consider Harbor Freights 500A tester for @$40 w/coupon...
NoRalPh is offline
The Following User Says Thank You to NoRalPh For This Useful Post:
Strokininthe208 (09-26-2017)
post #7 of 7 Old 09-26-2017, 03:46 PM Thread Starter
Quoted: 29 Post(s)
Alright thanks just gonna buy 2 new interstates.
