Blue smoke - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-10-2017, 08:59 AM Thread Starter
tony013's Avatar
Blue smoke
So yesterday I drove my 2000 f350 7.3 cclb maybe 20 miles at first I seen black smoke like it always does than after I let off throttle a puff of blue smoke. Happens every time I let off throttle to come to a stop. It's not a consistent stream of blue just a little puff and its got me worried. I did oil change last weekend and had the icp replaced on wed due to truck stalling out while driving. What could this issue be I notice the oil was a little over full. I guess the shop put more oil in after I told them I did the change on Saturday last week I drained to correct amount still puff of blue smoke HELP!!!
Sent from my iPhone using Tapatalk
tony013 is offline
post #2 of 10 Old 09-10-2017, 02:10 PM
greenskeeper's Avatar
Quoted: 302 Post(s)
How does the truck run besides the blue smoke?
If it runs good you could do a compression test for peace of mind, if that comes back good then it could be turbo seals.
Unless the truck is using oil I wouldn't worry about it.
Gunga galunga...gunga -- gunga galunga.
97 F-250 CC 4x4 7.3L PSD E4OD 203K all original
99 F-250 CC 4x4 7.3L PSD ZF6 253K all original
greenskeeper is offline
post #3 of 10 Old 09-10-2017, 04:13 PM Thread Starter
tony013's Avatar
Doesn't run through oil. Truck has the power that it started with before the blue smoke. Still builds boost no problem
tony013 is offline
post #4 of 10 Old 09-19-2017, 06:21 PM Thread Starter
tony013's Avatar
So had injectors replaced by ford this last week and it still blows a bit of blue grey smoke after I let off throttle. I'm Boggled
tony013 is offline
post #5 of 10 Old 09-20-2017, 01:37 PM
Montstroke's Avatar
Quoted: 5 Post(s)
Have you drove good and hard for a bit since the injectors to burn off ALL the oil that gets in the cylinders? Could also be an injector oring that got messed up on install.
2001 F250 CCSB
P.I.S. 160/30 single shots
RR Donaldson Blue Filter
KC38R w/.84
EBPV gone
AIH gone
Turbo back 4" MBRP muffled
Hydra w/ PHP tunes
315's with Zone level kit
On board air
Suspension air bags
Montstroke is offline
post #6 of 10 Old 09-20-2017, 04:34 PM
Quoted: 7 Post(s)
Valve guides?
Sent from my Pixel using Tapatalk
Chrabee is offline
post #7 of 10 Old 09-20-2017, 04:40 PM
JustinOOO9's Avatar
Quoted: 1702 Post(s)
Garage
Feedback Score: 3 reviews
Why did you have injectors replaced? Hopefully not because everyone thought that was the cause of the blue smoke?
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is offline
post #8 of 10 Old 09-20-2017, 07:41 PM Thread Starter
tony013's Avatar
No I had a clack noise and they were under wty so me “hey fix this injector issue and find out why it’s blowing blue” ford “2 bad injectors are bad and also causing the blue smoke” a day later still blowing blue puff on decel but not a full wot city driving mostly.
tony013 is offline
post #9 of 10 Old 09-25-2017, 08:38 PM Thread Starter
tony013's Avatar
Still at a loss! HELP!!!
tony013 is offline
post #10 of 10 Old 09-26-2017, 01:55 PM Thread Starter
tony013's Avatar
Can bad turbo cause blue smoke?
tony013 is offline
