upfitter switches in 2002 - Page 2 - Ford Powerstroke Diesel Forum
 3Likes
post #11 of 26 Old 01-19-2016, 02:47 PM
elephantrider's Avatar
Quoted: 205 Post(s)
in for pics. would like to add something like this on my 02.
02 joke
Originally Posted by djone10 View Post
I just bought an 05 powerstroke 6.0.
Any tips on what should be changed/checked other than oil change??
Originally Posted by Rolfsted View Post
Everything
elephantrider is offline
post #12 of 26 Old 01-19-2016, 03:45 PM
Quoted: 29 Post(s)
NormTinCO likes this.
Will335i is offline
The Following User Says Thank You to Will335i For This Useful Post:
Cumminpwr11 (01-19-2016)
post #13 of 26 Old 01-19-2016, 04:10 PM
Quoted: 461 Post(s)
Feedback Score: 3 reviews
I did it this way...
NoRalPh is offline
post #14 of 26 Old 01-19-2016, 04:57 PM
Originally Posted by Will335i View Post
did you completely rewire yours? I have the same panel but gray and I am about to buy the upfitters but I don't know if I need the whole module or just the switches and wire my own up.
I need a dumbies guide to wiring them up. I want to wire up my light bar, reverse lights, reverse camera and what ever else.
Chris
Chris
2005 Ford Excursion XLT 6.0 Livewire TS, 4" lift 37x13.50 22
Cumminpwr11 is offline
post #15 of 26 Old 01-19-2016, 05:10 PM
Quoted: 29 Post(s)
If you are getting the ford upfitters you want the wiring harness too. It will come with the relay, plug that goes into the fuse panel and the pigtails that you connect to your accessories. In my case I removed the plug and wired into my standalone fuse block. I don't know where my wiring diagram went but you should be able to do a google search to see what the wiring and fuse requirements are.
Will335i is offline
post #16 of 26 Old 02-07-2016, 12:52 PM
Quoted: 2 Post(s)
Garage
Has anyone used the upfitter switches with the trailer brake with it. does it work very well or is it not worth it. if its ant good it would look better that having the brake control under the dash.
NormTinCO is offline
post #17 of 26 Old 02-07-2016, 02:04 PM
Quoted: 28 Post(s)
From the research I did, the 05+ brake controllers coincide with the ECM, so it would not be a reasonable swap.
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, 180/30 FF, 444fab RR, DynoProven tunes, 38r, 6.0 cooler, 55w digital projector HIDs
gomer pyle is offline
The Following User Says Thank You to gomer pyle For This Useful Post:
NormTinCO (02-07-2016)
post #18 of 26 Old 02-07-2016, 02:08 PM
Quoted: 2 Post(s)
Garage
Thanks for the info.
post #19 of 26 Old 02-07-2016, 02:13 PM
Quoted: 28 Post(s)
I added them on my 2000. I had to add a aftermarket fuse block. I have all the wiring written down(I'll have to hunt for it) for the trucks with the older fuse blocks. 02+ should be able to plug right in. It takes a small amount of trimming and one tab had to be left loose to fit it in my truck.
[IMG][/IMG]
[IMG][/IMG]
post #20 of 26 Old 03-07-2016, 11:36 PM
Quoted: 4 Post(s)
I did it, and SSSSOOOOO WORTH IT!!!!!!! I love it!! works way better than the prodigy I had in before that was angle sensitive. This one works on brake pressure so it doesn't matter if you're going uphill or down, just how hard you push the pedal!
I don't remember which color wires run to the computer, but I just didn't hook them up and no problem. I got a good used 6.0 master cylinder with TBC port from a used parts yard, then had to splice the brake lines together since the connections are different. (I think its 3/16 brake line, of course someone will tell you it's metric but hell mine has held for almost 2 years without leaking)
One of the 2 plugs from the 6.0 TBC goes into the 7.3 harness (need to make an adapter so get the plugs with your 6.0 TBC) and then the other plug has 5 wires, 1 is hot, 2 to the master cylinder switch, and 2 to the computer (didn't use). The hardest part of the whole installation was moulding the upfitter and TBC plastic mounting to the bottom of my F650 center underdash, other than that it was pretty straight forward and gave me a chance to change out my brake fluid since I had to rebleed the bakes.
NEW TRUCK
'17
Crew cab
F350
Dualy
4x4
King Ranch
B&W 5th wheel hitch
91 gallon in bed fuel tank
SOLD
02 7.3
CC SB
4x4
P-rot is offline
