A/c issue - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Hydro
post #1 of 6 Old 08-25-2019, 09:21 PM Thread Starter
Jsalamon96's Avatar
Quoted: 10 Post(s)
A/c issue
2000 f350 with the conventional hvac system, had an issue earlier with a vacuum leak, fixed now if i use a/c or max a/c it blows ice cold then slowly quits blowing out the vents. Let it sit for a bit and then it works again. Nothing in the engine bay is freezing off
Jsalamon96 is offline
post #2 of 6 Old 08-26-2019, 11:19 AM
DesertDiesel's Avatar
Quoted: 71 Post(s)
Your blower motor could be going out. A lot of us have already had to replace them. Very easy and cheap fix. I'm thinking about replacing mine just so I don't have to worry about it going out on a long hot camping trip.
2000 7.3 4x4 CC, 210,000 miles.
Security: Ravelco (for the pro's), Viper (for the rookies), The Club 1100 Steering Wheel Lock (visual deterrent).
DesertDiesel is offline
post #3 of 6 Old 08-26-2019, 11:27 AM Thread Starter
Jsalamon96's Avatar
Quoted: 10 Post(s)
I was thinking of replacing it just as a predictive maintenance. I forgot to add that the fan speed doesn't fluctuate, it just slowly quits blowing out of dash vents but blows out the defrost vents
post #4 of 6 Old 08-26-2019, 03:56 PM
Quoted: 534 Post(s)
Garage
You still have a vacuum leak(hose) or a bad vacuum motor on the vent selector -- usually when the vacuum leaks off the air will only come out the defrost vents -- tee a gauge into one of the lines so you can see what the reading is -- a hand pump would help in diagnosing the vacuum motors
" ice cold then slowly quits blowing out the vents"
Are you saying no air at all out any of the vents -- or air only out the defrost?
Cause that is a whole different problem
Jjorgis5569 likes this.
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #5 of 6 Old 08-27-2019, 03:31 AM
Jjorgis5569's Avatar
Quoted: 83 Post(s)
Not quite sure about the exact symptoms, but my first impression was that it works normally for a while then air flow gradually decreases. If youíre saying that no air is coming from the vents, but the blower is still operating at max speed it sounds like a restriction. It could be the evaporator freezing over. If thatís the case try turning off the compressor and see if the airflow gradually returns, and air is still fairly cool. Could be that ice restricts air flow until the ice over the evap starts to thaw.
If thatís the case:
Whatís the humidity?
Have you checked the freon charge?
Any noises? Maybe like a faint whistling? There is a small chance the expansion valve isnít properly metering refrigerant.
Jjorgis5569 is offline
post #6 of 6 Old 08-28-2019, 04:25 PM Thread Starter
Jsalamon96's Avatar
Quoted: 10 Post(s)
I believe the evaporator is freezing off, ill check freon charge and the orfice tube next week
