Ignition will not turn back to lock - 2000 Excursion - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-21-2019, 06:23 PM Thread Starter
I have a 2000 Ford Excursion. Today I lowered the steering column to replace the shift tube. That whole process went fine and it all went back together as it should. Now, the issue i am having is the key will not turn back into the lock position. The truck will start fine, and when i turn it off it turns back far enough to kill all the power but stops before the lock position. And of course it will not go back to accessory either. I pulled the key tumbler out 12 times and checked everything, I just cannot figure out what would have happened. The part i replaced did not have anything to do with the key tumbler. Hopefully someone has been through this and can provide me some direction. Thanks everyone.
parkerexpress is offline
post #2 of 2 Old 07-21-2019, 06:39 PM Thread Starter
Well, fixed it. Turns out that even though it looked like it was in park, it was not all the way. I pulled on it harder and the key turned back. I will need to do some adjustment on that it appears. Hope this helps someone in the future.
