KC turbo wastegate setting? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 01-10-2020, 10:18 PM Thread Starter
00t444e's Avatar
Quoted: 618 Post(s)
I am getting a KC300x 63/73/.84 turbo on my truck. Anyone know what the wastegate is set at and if I need to adjust it? My wastegate actuator is currently unhooked and I plan on leaving it like that.
00 f250 ext. cab, lb, 4x4, 170,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, KC 300x 63/73/.84 turbo, PHP Hydra, Riff Raff frx,, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, Edge CS2, 4 in diamod eye straight pipe 6 in tip.
00t444e is online now
post #2 of 17 Old 01-17-2020, 01:58 PM Thread Starter
00t444e's Avatar
Quoted: 618 Post(s)
Bump, anyone know?
post #3 of 17 Old 01-17-2020, 03:02 PM
JustinOOO9's Avatar
Quoted: 1694 Post(s)
Garage
Feedback Score: 3 reviews
Originally Posted by 00t444e View Post
Bump, anyone know?
Have you reached out to KCTurbos directly?
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is online now
post #4 of 17 Old 01-17-2020, 05:52 PM Thread Starter
00t444e's Avatar
Quoted: 618 Post(s)
Good idea in theory but I always forget to call them during the hours that they are open, I guess I could try emailing them.
post #5 of 17 Old 01-17-2020, 08:02 PM
JustinOOO9's Avatar
Garage
Just figured most will probably offer their opinion based on googeling or experience but hearing from the manufacturer who designed it may give you the best info etc.
post #6 of 17 Old 01-17-2020, 08:56 PM
Quoted: 1466 Post(s)
Feedback Score: 4 reviews
I believe they are typically set at 35psi.
www.cncfab.us
post #7 of 17 Old 01-18-2020, 04:54 AM
02_7.three's Avatar
Quoted: 66 Post(s)
Garage
I have the same turbo. When I got it I called Charlie and he said the red hose is supposed to be unhooked.
2002 F-250 ECSB ZF6
FF 205/30's, KC 63/73, South Bend Clutch, CNC Fab 4 Line Feed, AEM 400
02_7.three is offline
post #8 of 17 Old 01-18-2020, 06:41 AM Thread Starter
00t444e's Avatar
Quoted: 618 Post(s)
Did you adjust the actuator rod any?
post #9 of 17 Old 01-18-2020, 06:54 AM
02_7.three's Avatar
Quoted: 66 Post(s)
Garage
No, they set them. Corey is correct they are set to about 35psi.
2002 F-250 ECSB ZF6
post #10 of 17 Old 01-20-2020, 04:40 PM
Quoted: 11 Post(s)
Red hose unhooked? Just installed mine a couple of months ago and i dont believe there was any notice in the box about leaving the hose off.. Is this how it is to be?
99.5 extended cab 2wd
back pressure valve delete
iah delete
WW2
full MBRP
PHP hydra
Edge insight
Riffraff air filter update
Woods valve body
6.0 trans cooler
FRX/HPX mod
Riffraff cac boots
1/2 Hutch mod
problmsolver is offline
