-6 an fittings on fuel pump - Ford Powerstroke Diesel Forum
post #1 of 1 Old 10-29-2019, 12:27 PM Thread Starter
Quoted: 40 Post(s)
Hi all, not sure this is the proper place to put it but I'll post here and please move of need be, long story short I put e fuel on my 94 powerstroke and used a 99 to 03 fuel pump, I'm redoing all my lines with pushlock fittings that are -6, does anyone know or has anyone done this and what did you use on the fuel pump itself? I can find the quick discont fitting the one that uses the tool to disconnect and the one that uses the little clip, I'm just not sure which ones I need for the pump to be certain. Any help would be appreciated, i believe on the pressure side i need the disconnect that requires the disconnect tool to remove but I'm not 100% sure about the suction/inlet side. Thanks for the help and guidance.
1994fordf350 is offline
