KC TURBO QUESTION - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 16 Old 07-26-2019, 09:54 AM Thread Starter
Needing New Turbo
i have a early 99 7.3L that is need of a new turbo. im not wanting to really upgrade to a bigger one but looking for a good company to purchase a stock one from any suggestions? or i would be interested in a used one that has low miles.
jacob.johns.jj is online now
post #2 of 16 Old 07-26-2019, 12:08 PM
DesertDiesel's Avatar
Quoted: 53 Post(s)
You could simply rebuild it if your housing isn't cracked. Could save you some money. New compressor wheel, turbine wheel and 360 degree bearing. What's wrong with it exactly?
2000 7.3 4x4 CC, short box, 207,500 miles.
PHP Hydra, Bilstein 5100's, Bilstein steering stabilizers, Auto Meter 3 gauge pod--EGT, Trans Temp & Boost, DieselSite 203*, Riffraff Billet wheel, 4" turbo back MBRP 5" straight pipe, Deep Trans Pan, Rotella ELC and T6 oil, Donaldson 6637 blue, 20" Fuel wheels wrapped with 37" MT's
Security: Ravelco (for the pro's), Viper (for the rookies), The Club 1100 Steering Wheel Lock (visual deterrent).
DesertDiesel is online now
post #3 of 16 Old 07-26-2019, 12:15 PM Thread Starter
the center bearing is making a roaring noise. the truck still functions and drives just the noise is about to drive me crazy!!
post #4 of 16 Old 07-26-2019, 04:19 PM
7.3lf550's Avatar
Quoted: 61 Post(s)
Few options
1-You tear it apart. New 360 bearings. Seals. Basic clean up.
2-Send it somewhere to get rebuilt
3-OEM or KC turbos IMO.
03 7.3l 550, FRx, 6637 mod, 4 inch turbo back, ccv delete, aih delete, HPx, Riffraffs OCR, Turbo-pyro-boost-coolant EV2 gauges, Bullydog GT tuner.
03 X 6.0 175/30 warren sticks, Livewire TS w/ warren tunes, Blue spring mod, atlas 40 ficm, 270amp dc power alt
Originally Posted by Heavy_GD View Post
goats lives matter.
7.3lf550 is offline
post #5 of 16 Old 07-26-2019, 09:07 PM
7.3_TurboDiesel's Avatar
Quoted: 84 Post(s)
You can find them in decent shape for dirt cheap on Facebook market place. Iím talking 2-300 bucks.
Or you could rebuild yours with the KC drop in turbine and compressor & rebuild kit ($450) that would give you a small bump in performance as well
Sent from my iPhone using Tapatalk
7.3_TurboDiesel is offline
post #6 of 16 Old 08-10-2019, 04:16 PM Thread Starter
Good Afternoon i purchased a KC300X 63/68 - 7.3 POWERSTROKE TURBO (E99) for my early 99 7.3 and my stock turbo had a flapper on the exhaust side that is controlled by an actuator off of the turbo pedestal the NEW KC Turbo does not have a flapper on the exhaust side or anywhere to hook up the rod off the pedestal. do i need to hook that rod up or did KC turbo send me the wrong turbo? it is suppose to be a drop in turbo ready to go. any help will be greatly appreciated.
someone please help!! i was wanting to finish this up tonight but not looking good.
post #7 of 16 Old 08-10-2019, 04:50 PM
00t444e's Avatar
Quoted: 542 Post(s)
That is the exhaust backpressure valve and actuator most people delete it because it is a common place for an oil leak. You can leave the rod unhooked and unplug the actuator for now.
7.3_TurboDiesel likes this.
00 f250 ext. cab, lb, 4x4, 158,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
The Following User Says Thank You to 00t444e For This Useful Post:
jacob.johns.jj (08-10-2019)
post #8 of 16 Old 08-10-2019, 04:58 PM Thread Starter
how do i delete it? just buy a pedestal without a rod?
if i leave it unplugged is it going to hurt anything? currently it is not leaking oil
post #9 of 16 Old 08-10-2019, 05:29 PM
00t444e's Avatar
Quoted: 542 Post(s)
You can get a delete pedestal or pull the rod out of yours, tap the hole and put a plug in it. Leaving it unhooked won't hurt anything.
00t444e is offline
post #10 of 16 Old 08-12-2019, 01:50 AM Thread Starter
My Uncle owns a weld shop i should be able to take the pedestal off and remove the rod and the front electrical portion and have the wholes welded up and it be just fine correct?
