Rear end help - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 24 Old 05-31-2019, 09:03 PM Thread Starter
Jake Herman's Avatar
Quoted: 8 Post(s)
Garage
Rear end help
Did Ford make a limited slip 3.73 for our 99-03 trucks? I'd love to start building up my axles but I'd like to swap out my unlimited slip 3.73 rear end for a limited slip. I'm not against welding my diff but would rather stay away and use it as a LAST CHANCE resort. I've heard of lockers but I'm not very educated on the matter or if they are for only hubs or if they actually lock the diff. I wanna go with Chromoly axle shafts and mag hytec diff covers for starters. Thanks, Jake.
Jake Herman is offline
post #2 of 24 Old 05-31-2019, 09:14 PM
SuperCrutyPS's Avatar
Quoted: 592 Post(s)
Garage
Yep - have one in my '01!
Darryl | Owner/Operator
Truck | 2001 F350 CCLB
5th Wheel |
Proud Veteran | US Navy - '76-'80 - Petty Officer 2nd Class (E5)
SuperCrutyPS is offline
The Following 2 Users Say Thank You to SuperCrutyPS For This Useful Post:
Jake Herman (06-01-2019)
post #3 of 24 Old 05-31-2019, 09:16 PM Thread Starter
Quoted: 8 Post(s)
Garage
How do you like it? Are they sorta rare?
post #4 of 24 Old 05-31-2019, 09:40 PM
Quoted: 592 Post(s)
Garage
I like it. It works well. I don't think they are rare, but not that sure. Maybe other members would know -or- Google could help.
5th Wheel |
post #5 of 24 Old 05-31-2019, 10:17 PM
30/06's Avatar
Quoted: 7 Post(s)
My 01 has it to. Works good also. My truck is the 01 crew cab long bed 4x4 lariat. I don't know if that made a difference or not.
Sent from my SM-G955U using Tapatalk
SuperCrutyPS likes this.
30/06 is offline
The Following User Says Thank You to 30/06 For This Useful Post:
post #6 of 24 Old 06-01-2019, 03:03 AM
00t444e's Avatar
Quoted: 542 Post(s)
Yes they made one but it wasn't that good. Get a Truetrac if you want a good limited slip. Or for ultimate strength and reliability get a Detroit locker like I did, the Yukon Grizzly locker is good also.
00t444e is offline
The Following User Says Thank You to 00t444e For This Useful Post:
post #7 of 24 Old 06-01-2019, 03:09 AM
00t444e's Avatar
Quoted: 542 Post(s)
Also unless your building a high HP competition truck, the stock axle shafts are fine. Axle shaft failure is rare on a Ford 10.25/10.50 unless it's under extreme abuse and high HP. That money would be better spent on a set of traction bars.
00t444e is offline
The Following 2 Users Say Thank You to 00t444e For This Useful Post:
post #8 of 24 Old 06-01-2019, 07:06 AM Thread Starter
Quoted: 8 Post(s)
Garage
Do you happen to have the part number for the Detroit locker so I could check it out?
post #9 of 24 Old 06-01-2019, 08:38 AM
1Macaw's Avatar
Quoted: 4 Post(s)
What does welding a limited slip do ? My 01 has the 4.10 limited in it I believe. I have considered traction bars but never really liked into them, mines 2wd ....
Sent from my XT1650 using Tapatalk
1Macaw is offline
post #10 of 24 Old 06-01-2019, 12:02 PM
00t444e's Avatar
Quoted: 542 Post(s)
Detroit locker 225SL56A
00t444e is offline
