any more whistle? - Page 2 - Ford Powerstroke Diesel Forum
 6Likes
post #11 of 26 Old 03-25-2019, 10:39 AM
Hate stupid people
CloverLeafFarm's Avatar
Quoted: 319 Post(s)
Originally Posted by Brycefow View Post
Yes they lower egts and improve air flow and give you a little higher boost but itís a 7.3. I have a tone dumped into mine. 200/150 injectors,regulated return, air dog (junk), CFm intake, built trans, water meth injection, etc and would get walked on by a 5.9 with a edge when with a 6.0 with 155/30s with a power max and a good tune itís a completely different truck than stock
Sent from my iPhone using Tapatalk
A proper combo on a 7.3 would walk both of those examples. I was doing it almost 10 years ago on the street/strip and hooked to a sled. Then drove home and got back to work.
Originally Posted by 00t444e View Post
Sounds like something is wrong, you should be over 500 HP with that setup.
depends on the turbo and what a "200/150" injector is? none of the reputable shops/builders ive ever worked with/heard of use a 150% nozzle
Illiana Strokers DICtator
EFI Live tuned 6.7
CloverLeafFarm is offline
post #12 of 26 Old 03-25-2019, 10:43 AM
00t444e's Avatar
Quoted: 559 Post(s)
I am assuming he meant 250/100s.
00 f250 ext. cab, lb, 4x4, 158,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #13 of 26 Old 03-25-2019, 10:45 AM
Quoted: 37 Post(s)
Yes I did 100s sorry my 6.0 has 235 150s
Brycefow is offline
post #14 of 26 Old 03-26-2019, 11:13 AM
never experienced it. but this is a very interesting discussion to follow
adalah is offline
post #15 of 26 Old 03-27-2019, 06:13 AM
mcnance865's Avatar
Quoted: 11 Post(s)
So you have 250/100, but you didn't mention an upgraded turbo. You would need an s369 or better to take advantage of those sticks. What is your turbo setup?
mcnance865 is offline
post #16 of 26 Old 03-27-2019, 08:47 AM
Quoted: 37 Post(s)
I had a 38r on it (powermax) then put wheels in it that being said it was ok I didnít have a egt issue till I put something behind it I no longer have the truck I know the guy swapped it to a t4 after he got it but donít know the size
Brycefow is offline
post #17 of 26 Old 03-27-2019, 10:39 AM
Hate stupid people
Quoted: 319 Post(s)
250/100 with a 38r is a fun setup when tuned properly.
i loved my 250/100s and my s366 setup. .91 housing was a rocket early on, but after adding 200% nozzles the billet wheel and 1.1 housing was a slightly slower light until about the 100' mark
EFI Live tuned 6.7
post #18 of 26 Old 03-27-2019, 12:19 PM
Quoted: 37 Post(s)
I plan to build a 7.3 down the road to see what we can push out of it
Brycefow is offline
post #19 of 26 Old 04-04-2019, 05:21 AM
Originally Posted by Billy231 View Post
Is this really an issue to discuss?
I think it is. I heard a 6.0 start up outside O'Reilly's the other day. Sounded like a 747 getting ready to take off. I have a 7.3 that I would love to hear more whistle out of but unless I'm sitting next to a building or something that will reflect the sound I can't hardly hear it. I talked to the guy that owned the truck and he said 7.3s were pretty quiet. He said there was a 'damper ring' at the turbo inlet that quieted things down, but it only really made a difference on the front end noise of the turbo.
aj110557 is offline
post #20 of 26 Old 04-04-2019, 05:24 AM
Hate stupid people
Quoted: 319 Post(s)
you can't compare a vgt 6.0 sound to a 7.3 non vgt turbo sound.
like comparing a 6.7 powerstroke to a idi
and no there isn't a "damper ring" in the turbo
you'll never ever get a similar whistle
Brycefow likes this.
EFI Live tuned 6.7
Similar Threads
Thread Thread Starter Forum Replies Last Post
Whistle under load and oil leaks. x225x 99-03 7.3L Powerstroke Problems 2 09-12-2018 05:47 AM
2016 6.7 Powerstroke Turbo Whistle Cshipley57 6.7 Performance Parts Discussion (2011-2016) 20 06-09-2018 08:00 AM
Turbo whistle gholscher General 6.7 Discussion (2011-2016) 2 03-08-2018 04:01 AM
Loud whistle at 10psi while cruising 06cris 6.4L Problems Forum 6 07-09-2017 06:46 PM
Powermax Turbo with no whistle? tgi_natedawg 6.0L Performance Parts Discussion 5 11-17-2016 08:18 PM
