KC Drop in s300 turbine with billet wheel turbo testing - Page 2 - Ford Powerstroke Diesel Forum
 14Likes
post #11 of 23 Old 04-15-2019, 12:48 PM
00t444e's Avatar
Quoted: 608 Post(s)
My 180/80s work great, and I have been running them on a stock turbo with a billet wheel for over a year.
00 f250 ext. cab, lb, 4x4, 158,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #12 of 23 Old 04-15-2019, 01:49 PM Thread Starter
peixinho's Avatar
Quoted: 349 Post(s)
For all those claiming to run stage 2s and "love them"... what else have you ran to compare?
I can tell you that ANY tuner or turbo builder that you talk to will say 9 times out of 10 the stage 1.5s or hybrids work better than the stage 2s. When you sell enough tunes/turbos/injectors you see a trend... and the most problematic, hot/smokey, injectors are the stage 2s (160/80, 160/100, 180/80, and 180/100)
Not that you "can't" run them. But just about any other injector out there is going to run better.
for the whole "30% nozzles is not big enough"... that is "kind of true"
at 4.2ms we only made 440hp with 180/30 but turning it up to a crazy 5.6ms we made 470hp
With 180/100s we made 490hp... but ran way hotter, way more smoke, harder to tow, touchy pedal and had major ICP issue
If you want more fuel than a 180/30 can provide... then bump up to 205/80s or 238/80s IMO. They will make more power, run cooler, and hold ICP better than 180/100s
We just had a guy switch from 180/100 to 205/30... and lost 20hp above 2500rpms... but gain MPG, cooler egts, less smoke, and more tq down low. So yes the 100% nozzle will increase top end power above 2500rpms, but at a sacrifice.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #13 of 23 Old 04-15-2019, 01:52 PM Thread Starter
peixinho's Avatar
Quoted: 349 Post(s)
Originally Posted by Slimline View Post
Unfortunately I already have the injectors. Would it be feasible to swap out the nozzles to make em 180/30? At the time I bought them they were the best "bang for buck" I could afford.
Since you already have them.... then I would just run them. But a stock size turbo will not fully clean up the top end on a race tune. But towing and normal driving should be fine.
I really like our new 63/73 with 180cc injectors
KC Turbos
peixinho is offline
post #14 of 23 Old 04-15-2019, 02:29 PM
7.3_TurboDiesel's Avatar
Quoted: 121 Post(s)
Have you ever had your truck on a dyno? And how do they run as far as EGTs and smoke with a stock turbo?
Sent from my iPhone using Tapatalk
7.3_TurboDiesel is offline
post #15 of 23 Old 04-15-2019, 02:47 PM
00t444e's Avatar
Quoted: 608 Post(s)
Haven't had it on a dyno. It will smoke if I lug it but for normal driving they run pretty clean, and the turbo cleans them up OK on the top end. Egts aren't an issue at all, on a full throttle 6th gear pull I am going nearly 100 mph before egts hit 1200*. No problems towing either but I haven't towed more than 6K.
00t444e is offline
post #16 of 23 Old 04-15-2019, 08:27 PM
Quoted: 121 Post(s)
Ok that makes me feel better then. Id like to upgrade the turbo at some point but its good to know I can keep it stock with the bigger injectors for the time being
post #17 of 23 Old 04-16-2019, 07:26 AM
sbluke55's Avatar
Quoted: 892 Post(s)
Garage
Story of my life. Poor decision on my part for buying my 160/100s.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #18 of 23 Old 04-16-2019, 09:18 AM
Quoted: 121 Post(s)
Did you have icp issues with the 160s?
post #19 of 23 Old 04-16-2019, 09:46 AM
sbluke55's Avatar
Quoted: 892 Post(s)
Garage
Yes. I still do.
01 f-250, Standard
sbluke55 is offline
post #20 of 23 Old 04-16-2019, 09:52 AM
White_Buffalo7.3's Avatar
Quoted: 191 Post(s)
Garage
https://rover.ebay.com/rover/0/0/0?m...2F254187662502
Pretty point less but you could swap nozzles
180/30s,KC38R, CNC Fab Stg 2 HPOP, Sump, Walbro, Donaldson 6637, Leveled, 4'' straight to 7'' tip, 08 mirrors, 6.0 front end ect...
White_Buffalo7.3 is offline
