Largest injector for kc38r with .84? - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 24 Old 02-02-2018, 02:31 PM Thread Starter
early99psd's Avatar
Quoted: 37 Post(s)
What would be the largest injector for a kc38r with a .84? Looking for a good tow injector.
Sent from my iPhone using Tapatalk Pro
KC38R, CNC Fab stage 1 HPOP, PHP Hydra, (1023, Gearhead & PHP tunes), AFE stage 2, 4" turbo back exhaust, gutted cat, ford reman trans, JW valve body, 6.0 trans cooler, EGT trans temp boost gauges, Hutch and Harpoon mod, riffraf FRx, Pro Comp leveling kit, 1" zone shackels, 08 rear diff cover, 315 Toyo AT2,
early99psd is offline
post #2 of 24 Old 02-02-2018, 06:35 PM
00t444e's Avatar
Quoted: 622 Post(s)
From what I understand you can run anywhere from stock to 238/80 injectors with that turbo.
00 f250 ext. cab, lb, 4x4, 170,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, KC 300x 63/73/.84 turbo, PHP Hydra, Riff Raff frx,, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, Edge CS2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #3 of 24 Old 02-02-2018, 06:37 PM Thread Starter
early99psd's Avatar
Quoted: 37 Post(s)
How do you like your injectors?
post #4 of 24 Old 02-02-2018, 06:44 PM
00t444e's Avatar
Quoted: 622 Post(s)
Well I would love to tell you but my truck has been down for a couple months for some body work, paint, and some other upgrades so I haven't driven it since I put the injectors in. I hope to get it back together in a few weeks depending on my schedule, they sound good at idle.
00t444e is offline
post #5 of 24 Old 02-02-2018, 06:46 PM Thread Starter
early99psd's Avatar
Quoted: 37 Post(s)
You will have to let us know when you get it back on the road. I would like to know how a PIS 160/30 compares to a full force 180/80
post #6 of 24 Old 02-02-2018, 06:52 PM
00t444e's Avatar
Quoted: 622 Post(s)
I will be writing a review on my Detroit locker, injectors, and PMF traction bars soon.
Billy231 likes this.
00t444e is offline
post #7 of 24 Old 02-02-2018, 06:54 PM Thread Starter
early99psd's Avatar
Quoted: 37 Post(s)
I am running a PMF trackbar, they make some quality stuff
post #8 of 24 Old 02-02-2018, 11:03 PM
DieselDC's Avatar
Quoted: 682 Post(s)
250/200 is the max with this turbo...
Just something to ponder though.... Dieselsite made 600hp with the gtp38r and the ww2. kC38r is by far a superior turbo than the stocker.
DieselDC is offline
post #9 of 24 Old 02-04-2018, 08:33 AM
Quoted: 1468 Post(s)
Feedback Score: 4 reviews
It really depends on how you drive your truck and it's use.
Lower AR spools quicker off the line, but will run out of air on the top end. Higher AR spools slower, but you gain top end.
Handshaker transmissions can be better suited with the .84 even with larger injectors due to you loosing boost between shifts, so the smaller housing helps you recover power quicker.
Tire size and gearing also make a difference.
It really boils down to how you drive your truck and the mods it has.
www.cncfab.us
post #10 of 24 Old 02-04-2018, 08:54 AM
DieselDC's Avatar
Quoted: 682 Post(s)
I think btwn the .84 and the 1.0 I went with the 1.0 b/c of top end. Was afraid the .84 would be restrictive if I wanted larger sticks. I believe you wonít lose much and more to gain with the 1.0
DieselDC is offline
