KC Turbo KC38r - Page 11 - Ford Powerstroke Diesel Forum
 53Likes
post #101 of 113 Old 12-20-2017, 02:54 AM
I got mine last week still gathering other parts so I can do it all at once... 😭😭
Billy231 likes this.
03 f.250
08 f.350- sold
Tellis88 is offline
post #102 of 113 Old 12-21-2017, 03:18 PM
mcnance865's Avatar
Quoted: 11 Post(s)
@[email protected]
The truck is pretty sluggish off the line already, but causes more issues with the TC locked up on hills. I did notice that this became more of an issue after putting on the hydra. I had an older SCT plug in tuner for the last 10 years or so and never really noticed any issues on hills because it would just kick down pretty quickly and away I went. With the Hydra chip, it definitely wants to try and lug through instead of shift; can that be accounted for in tuning? Will I noticed an even bigger jump in the TC/off the line/lugging issue I had going from SCT to Hydra when I jump up all that power with the new sticks? I am hoping that I can get the new setup going and run some tunes that account for the tire size and gearing until I save up to have it regeared, as I agree a 4.30 gear would be optimal.
mcnance865 is offline
post #103 of 113 Old 12-21-2017, 03:21 PM
mcnance865's Avatar
Quoted: 11 Post(s)
Also, I am running the canned tunes from PHP. I have to think that the shift points are thrown off due to truck not realizing actual speed. I know the VSS doesn't consider tire size, but I still think there is an issue there because going up hills it just does not want to down shift unless i hit the brake hard and then throttle hard to force a down shift.
2000 F-250 4x4 SuperCab Short Bed 7.3 w/ 280,xxx mi - 4" Pro Comp - Redhead - 37x12.50x17 BFG A/T KO - 3.73 Gears - CTS2 - Hydra - FFD 238cc/80%
KC38r 366 - Adrenaline - Irate Fuel System w/ Sump - 4"Exhaust - K&N CAI w/ S&B Filter - FFD Bellowed Up Pipes - AIH Plug - RiffRaff Plenums & Boot Kit
post #104 of 113 Old 12-21-2017, 07:31 PM
Corey@CNCFAB's Avatar
Quoted: 1429 Post(s)
Feedback Score: 4 reviews
See if PHP will modify your stock tunes for the tire size.
www.cncfab.us
[SIZE="3"]For all your ford powerstroke needs. If you dont see what you are looking for on the website, please use the contact page and shoot us a message or
Part numbers will help alot too if they are not on our site.
post #105 of 113 Old 12-22-2017, 04:39 AM
Quoted: 46 Post(s)
[[email protected];15600466]See if PHP will modify your stock tunes for the tire size.]
You will enjoy that conversation.
97 F350 XL std cab, zf5, srw (converted), 4wd, 3.55s, stock wheels/tires & rebuilt 9.18
2 Donaldsons, 3" dp, ACs, T500, HV LPOP, Hydra w/PHP, DIY 60 gl tank w/6 gl sump, eFuel/Cat filters, Aeromotive RR, Auber instruments, 140v IDM, KC 300X 63/70/84, boost fooler, RiffRaff bellowed up pipes, 6.0 IC, 3" plenums w/RiffRaff inserts & SB 425HD
MeTo is offline
post #106 of 113 Old 12-22-2017, 06:40 AM
mcnance865's Avatar
Quoted: 11 Post(s)
@MeTo I sense a little sarcasm! Haha I'm assuming you went through that process and were not impressed?
@[email protected] I will be getting all the upgrades put on here in the next few weeks so I am not even going to bother trying to change the stock tunes. It really isn't that bad, but I definitely notice it because I know it is not running like it could/should.
[email protected] likes this.
post #107 of 113 Old 12-22-2017, 06:56 AM
Billy231's Avatar
Quoted: 62 Post(s)
Garage
Makes a lot of sense regarding tire size/gear ratio with tall tires but what about the turbo outlet size, .84 or 1.0??
Corey can tell you more if youíve got the 1.0 as he had explained to me which the smaller size will spoil quicker/no lag.
I have a KC billet wheel in stock turbo currently .84 deleted outlet on PHP canned tunes, 3.73 ratio on 275/70-18 tires and on 80hp TT mode @72 mph =2000rpm in OD Iíll be on a steep uphill grade and will be effortless @1000-1100egt (4K-enclosed trailer)
Canít wait to try the KC38R in same scenarios.
Those tall tires have to be killing you with gears.
Sent from my iPhone using Tapatalk
Billy231 is offline
post #108 of 113 Old 12-22-2017, 08:17 AM
mcnance865's Avatar
Quoted: 11 Post(s)
I am still on a bone stock turbo right now. I have not put the new one in yet. But yes the gearing is starting to be a lot more noticeable. I actually think the power increase of switching to the Hydra made this issue worse. By that I mean, it has more power at any given RPM and it takes less rpm to get to certain speed, there-go I am driving under the turbo a lot more than I ever was just using the SCT tuner.
post #109 of 113 Old 12-22-2017, 12:09 PM
Quoted: 25 Post(s)
Here is a good read on the speedo and trans shifty with regards to larger tires.
https://www.ford-trucks.com/forums/1...ft-points.html
I will admit, I find that with 35s most tunes that are DD 'feel' like they short shift.
akcooper9 is offline
post #110 of 113 Old 12-22-2017, 12:27 PM
mcnance865's Avatar
Quoted: 11 Post(s)
That was a very good thread you posted @akcooper9 ! I realize that "technically" the trans is still shifting at the same rpm/time/speed. However, this does not account for the extra load of the bigger tires or the now improper gearing. I guess my question becomes, is there a way to tune for this so that the TC does not lock up on a hill and not shift down? (this happens often with the Hydra, but never happened with the old SCT). I am planning to switch to 4.30 gears at some point, but just wondering if this can be corrected with tuning.
