Gauges on an '02 Auto - Page 2 - Ford Powerstroke Diesel Forum
 1Likes
post #11 of 18 Old 04-19-2015, 02:15 PM
Quoted: 13 Post(s)
Trans temp! Stock gauges are a guess at best. I got my entire setup from dieselmanor. Included everything which includes hardware/electrical tidbits. Easy install.
MNguy is offline
post #12 of 18 Old 04-19-2015, 02:42 PM
sbluke55's Avatar
Quoted: 892 Post(s)
Garage
Corey at cncfabricationllc.com has the best prices I've seen
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #13 of 18 Old 04-19-2015, 05:28 PM Thread Starter
Quoted: 19 Post(s)
Originally Posted by Joel View Post
If you're serious about the truck you need EGT, Fuel Pressure, Volts, Trans temp, and Boost.
But if you're even more serious you can get a monitor to do most of that and also ICP and IPR which can be pretty darn important.
Now you have me thinking. Would something like the Edge Insight CTS catch all of those things (with an EGT probe)? Would the Torque Pro app?
I do love the look of the gauges but would rather make sure I'm covering all of the bases
2000 ECLB 4x4 7.3L PSD - Converted from a beat up XL farm truck and frame off restored thanks to New England road salt
Cosmetic: 05 Harley front end, 11 tailgate, black sport full power interior, 05 dash with aux switches and brake controller
Performance: AFE intake, SPX billet compressor wheel, Turbomaster wastegate, blank pedestal & exhaust housing, MBRP 5" exhaust, PHP Hydra, gauges and CTS2
Audio: Sony XAV-AX5000, JBL Club speakers, fully sound deadened
Lt.Dan is offline
post #14 of 18 Old 04-19-2015, 05:34 PM
Joel's Avatar
Quoted: 10 Post(s)
The edge insight is expandable to do pretty much everything you could want, the only problem is the expansions are very expensive.
If I was starting from scratch I would use real gauges for Boost, EGT, and Fuel Pressure while leaving the rest to the insight.
The edge also allows you do view codes and clear them while driving along the highway.
On my truck I relocates the Intake Air Temp sensor to the bumper and I monitor that on the edge as well as my outside air temp gauge. It's very accurate
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #15 of 18 Old 04-19-2015, 06:31 PM Thread Starter
Quoted: 19 Post(s)
I think I've decided that my plan is do to 3 gauges on the pillar, then the remaining two on an f650 lower dash (at a later date).
So, in the short term, I think I'll go pyro, EGT and fuel pressure on the pillar.
What fuel pressure is normal and what are the likely causes if out of the normal range?
Lt.Dan is offline
post #16 of 18 Old 04-19-2015, 06:38 PM
Corey@CNCFAB's Avatar
Quoted: 1460 Post(s)
Feedback Score: 4 reviews
55psi. But 45-65 is desired. 45 being at WOT.
Getting all those analog gauges will be in the same price range as getting the CTS with EAS expendable kit and will monitor everything. FYI, Isspro makes the electronic sensors for EDGE.
CTS may actually be less money right now, as Edge just emailed me Friday and let us extend the 10% off until May 5th.
[SIZE="3"]For all your ford powerstroke needs. If you dont see what you are looking for on the website, please use the contact page and shoot us a message or
Part numbers will help alot too if they are not on our site.
post #17 of 18 Old 04-19-2015, 06:57 PM Thread Starter
Quoted: 19 Post(s)
My concerns with an electronic monitor is that the reading are taken through the PCM. Are the readings this receives comparable in accuracy to standalone units? (mostly trans temp, boost, and fuel pressure)
And Corey, expect an order of HPOP lines from me within the next month or so, my 6mo old stock ones are leaking already (shop installed by previous owner)
Lt.Dan is offline
post #18 of 18 Old 04-19-2015, 07:11 PM
10-4 on the oil lines.
Keep in mind the sensors on your truck that the PCM sees have to be very very accurate. If they are not, then tuners would have a helluva time trying to dial a truck in.
The Following User Says Thank You to [email protected] For This Useful Post:
Lt.Dan (04-20-2015)
