You know you own a 7.3 when... - Page 33 - Ford Powerstroke Diesel Forum
 246Likes
post #321 of 400 Old 11-25-2014, 10:04 AM
Austen's Avatar
Quoted: 55 Post(s)
You know you own a 7.3 when the worst thing that happens is you blow out injector o-rings.
Not blown heads, completely destroyed short blocks, high pressure fuel system failures.
Cracked pistons, leaky radiators, failed EGR coolers, pre-mature turbo & injector failures, sensitive fuel systems, dropped valves, cracked heads, cab off jobs, excessive rocker arm wear, blown head gaskets, worn steel to steel "valve guides." No "redesigning" of the motor to make it reliable and last a long time.
Austen is offline
post #322 of 400 Old 11-25-2014, 10:36 AM
nine6stroker's Avatar
Quoted: 44 Post(s)
When you buy a cheap beater car that gets 35+ mpg to keep the miles off your truck and save fuel, and yet you still drive the truck 80% of the time because it feels like a part of you is missing when you aren't driving it
nine6stroker is offline
post #323 of 400 Old 11-25-2014, 04:04 PM
700xxmaniac's Avatar
^ this guy is 100% right.. I drive 100 miles a day.. Haven't driven my car in over a month
700xxmaniac is offline
post #324 of 400 Old 11-25-2014, 04:56 PM
Austen's Avatar
Quoted: 55 Post(s)
Same here, lol.
I've thought about getting a car but it would have to be something really nice for me to want to drive it. That said, it would be something that would not get great mileage and require premium grade fuel so in the end I would just be in the same place that I am now.
Austen is offline
post #325 of 400 Old 11-25-2014, 05:57 PM
Joel's Avatar
Quoted: 10 Post(s)
True story.
My wife's kid hauler and grocery getter is a blacked out Hemi Magnum R/T
I like driving it, but it's about the same on fuel as my truck. Feels hardly any faster either
Austen likes this.
Joel is offline
post #326 of 400 Old 11-26-2014, 06:35 PM
Spud Monkey's Avatar
Quoted: 59 Post(s)
Originally Posted by sbluke55 View Post
A little more explanation is required. Pics?
Up in mountains getting firewood, went down to get fuel from gf for chainsaw and got out to get it from her, left truck idling and down it went. Thought it was parked against rock pretty good but guess the incline cause it to roll over it. Only thing that stopped it in the end was headache rack catching it. Took me three days with harbor freight 3 ton chain hoist, two chains, shovel, hi-lift jack, 100 foot of cable and a lot of cribbage. Not easy doing it yourself.
DaveP. and Lt.Dan like this.
Spud Monkey is offline
The Following User Says Thank You to Spud Monkey For This Useful Post:
TGHill (11-27-2014)
post #327 of 400 Old 11-27-2014, 08:59 AM
Quoted: 2 Post(s)
^^ WOW at those pics.
sbluke55 likes this.
TGHill is offline
post #328 of 400 Old 11-27-2014, 03:01 PM
JJFLASH's Avatar
Quoted: 111 Post(s)
Hole mother %$#%@^& Spud!! That's rank. You recovered it 100% by yourself with basic tools and a chain hoist??
JJFLASH is offline
post #329 of 400 Old 11-27-2014, 05:33 PM
Quoted: 59 Post(s)
Yeah I couldn't afford a tow truck which I know they would of had to use two at the least and that if they had one strong enough, plus it was in National Forest and it isn't exactly flat logging roads they purposely made dips in it that most vehicles can't get through. In order to get the cab off the tree it was wedged on I deflated the passenger side tires. So first day spent trying with 3000 lbs ratchet straps I had on truck with chain hoist and couple chains that just snapped them after a bit. Second day came back with cable to attach to chain hoist and pulled it back some more but drivers side wheel got wedge on tree root at the last leg of the pull and was worn out from working chain hoist all day. Third day came back and that's where the pictures you see with hi-lift jack picking the whole front up and putting cribbage down as I went. PITA working on side of mountain trying to prevent myself from sliding down. The more truck came up the more it wanted to sink in side so I shoveled a bit too to help the chain hoist as I accidentally pulled one tree down in process. So that brings me to this part https://www.powerstroke.org/forum/mil...n-do-take.html
I can say one thing but to see me in action speaks volumes.
post #330 of 400 Old 11-27-2014, 05:59 PM
JJFLASH's Avatar
Quoted: 111 Post(s)
Apparently I don't have clearance to see that link so I'll take your word for it.
JJFLASH is offline
The Following User Says Thank You to JJFLASH For This Useful Post:
huizenga7 (05-14-2015)
