Vin# - Ford Powerstroke Diesel Forum
post #1 of 15 Old 09-20-2006, 09:40 AM Thread Starter
Vin#
Can anyone tell me what character in the VIN indicates a PSD? IM lloking for a truck and have found three but all I can pull up s the VIN and A pic.
JEEPERV89 is offline
post #2 of 15 Old 09-20-2006, 09:55 AM
Conservative and Proud
Banshee34's Avatar
Quoted: 9 Post(s)
I know we had a thread about it somewhere, but search doesn't seem to be working properly....
Soooooo, I found this on the net for ya...it's a pdf file, so I hope you have that.
Vin
2001 F350, Lariat SC LB 4X4 PSD
Quadzilla Commander
Zoodad with Stealth Screen
The Org. Staff reserves the right to move, modify, delete or merge posts at our discretion and without explanation.
Banshee34 is offline
post #3 of 15 Old 09-20-2006, 09:55 AM
Glenn M's Avatar
The 8th character is F for the 7.3 PSD
VIN NUMBER:
The first three vehicle identification number (VIN) positions are the world manufacturer code.
1FD Ford Motor Company, USA, incomplete vehicle
1FM Ford Motor Company, USA, multi-purpose vehicle
1FT Ford Motor Company, USA, truck, completed vehicle
2FM Ford Motor Company, Canada, multi-purpose vehicle
3FD Ford Motor Company, Mexico, incomplete vehicle
The fourth VIN position is the vehicle brake type and GVWR code (all vehicles use hydraulic brakes).
N 8,501-9,000 pounds GVWR with driver and front passenger air bags
S 9,001-10,000 pounds GVWR with driver and front passenger air bags
W 10,001-14,000 pounds GVWR with driver and front passenger air bags
X 14,001-16,000 pounds GVWR with driver and front passenger air bags
A 16,001-19,500 pounds GVWR with driver and front passenger air bags
H 8,501-9,000 pounds GVWR, without air bags (Mexico)
J 9,000-10,000 pounds GVWR, without air bags (Mexico)
K 10,001-14,000 pounds GVWR, without air bags (Mexico)
L 14,001-16,000 pounds GVWR, without air bags (Mexico)
M 16,001-19,500 pounds GVWR, without air bags (Mexico)
Positions 5 through 7 indicate vehicle line, series and body type.
F20 F-250, Regular Cab, 4x2, single rear wheels
X20 F-250, SuperCab, 4x2, single rear wheels
W20 F-250, Crew Cab, 4x2, single rear wheels
F21 F-250, Regular Cab, 4x4, single rear wheels
X21 F-250, SuperCab, 4x4, single rear wheels
W21 F-250, Crew Cab, 4x4, single rear wheels
F30 F-350, Regular Cab, 4x2, single rear wheels
X30 F-350, SuperCab, 4x2, single rear wheels
W30 F-350, Crew Cab, 4x2, single rear wheels
F31 F-350, Regular Cab, 4x4, single rear wheels
X31 F-350, SuperCab, 4x4, single rear wheels
W31 F-350, Crew Cab, 4x4, single rear wheels
F32 F-350, Regular Cab, 4x2, dual rear wheels
X32 F-350, SuperCab, 4x2, dual rear wheels
W32 F-350, Crew Cab, 4x2, dual rear wheels
F33 F-350, Regular Cab, 4x4, dual rear wheels
X33 F-350, SuperCab, 4x4, dual rear wheels
W33 F-350, Crew Cab, 4x4, dual rear wheels
F34 F-350, Regular Cab (Chassis Cab), 4x2, single rear wheels
X34 F-350, SuperCab (Chassis Cab), 4x2, single rear wheels
W34 F-350, Crew Cab (Chassis Cab), 4x2, single rear wheels
F35 F-350, Regular Cab (Chassis Cab), 4x4, single rear wheels
X35 F-350, SuperCab (Chassis Cab), 4x4, single rear wheels
W35 F-350, Crew Cab (Chassis Cab), 4x4, single rear wheels
F36 F-350, Regular Cab (Chassis Cab), 4x2, dual rear wheels
X36 F-350, SuperCab (Chassis Cab), 4x2, dual rear wheels
W36 F-350, Crew Cab (Chassis Cab), 4x2, dual rear wheels
F37 F-350, Regular Cab (Chassis Cab), 4x4, dual rear wheels
X37 F-350, SuperCab (Chassis Cab), 4x4, dual rear wheels
W37 F-350, Crew Cab (Chassis Cab), 4x4, dual rear wheels
F46 F-450, Regular Cab (Chassis Cab), 4x2
W46 F-450, Crew Cab (Chassis Cab), 4x2
W42 F-450, Crew Cab (with box), 4x2, dual rear wheels
W43 F-450, Crew Cab (with box), 4x4, dual rear wheels
F47 F-450, Regular Cab (Chassis Cab), 4x4
W47 F-450, Crew Cab (Chassis Cab), 4x4
F56 F-550, Regular Cab (Chassis Cab), 4x2
W56 F-550, Crew Cab (Chassis Cab), 4x2
F57 F-550, Regular Cab (Chassis Cab), 4x4
X46 F-450, SuperCab (Chassis Cab), 4x2
X47 F-450, SuperCab (Chassis Cab), 4x4
X56 F-550, SuperCab (Chassis Cab), 4x2
X57 F-550, SuperCab (Chassis Cab), 4x4
W57 F-550, Crew Cab, (Chassis Cab), 4x4
U40 Excursion, 4x2, XLT
U41 Excursion, four-door, 4x4, XLT
U42 Excursion, four-door, 4x2, Limited
U43 Excursion, four-door, 4x4, Limited
The eighth VIN position is the engine displacement and number of cylinders.
L 5.4L, Modular, SOHC, EFI, V8, Gas
S 6.8L, SOHC, EFI, V10, Gas
F 7.3L, OHV, DI Turbo, V8, Diesel
Z 6.8L, gaseous fuel prep (F-Series)
D 6.8L, propane only (F-Series)
B 5.4L, propane only (F-Series)
The ninth VIN position is a government assigned, computer-generated check digit.
The tenth VIN position is the model year code.
2 2002
The eleventh VIN position is the assembly plant code.
S Allen Park (Allen Park, Michigan)
E Kentucky Truck (Jefferson County, Kentucky)
M Cuautitlan (Cuautitlan, Mexico)
The last six VIN positions are an alphanumeric code for the vehicle build sequence. This is also the vehicle serial and warranty number.
A0000-E99999 Ford Division
Glenn
The only time it ends, is when your pockets are totally empty!
2001 4x4 F-250 SD,SC,SB, Lariat, PSD, HX cross over, DT466 cps, Ford AIS intake, 4" Pinnacle pipe, built trans, Dacco 3disk converter, Isspro pillar gages. MAP reg., ZooDad Mod,TS 6-pos chip,Truxedo/Plus Tonneau.
Glenn M is offline
post #4 of 15 Old 09-20-2006, 10:01 AM
josh_tn's Avatar
I just checked what you posted with the VIN# from my insurance card and it doesn't seem to match up. For instance, my first 3 digits are 3FT which I don't see there and according to my VIN#, my truck has the 6.8L V10 which is obviously not the case.
So, is my VIN# wrong, is this information incorrect, or has my truck been changed before I bought it? Inquiring minds...
josh_tn is offline
post #5 of 15 Old 09-20-2006, 10:21 AM
Glenn M's Avatar
3FT means your truck was built in Mexico = complete vehicle.
What's your vin# leave off the last 6 digits?
Glenn
Glenn M is offline
post #6 of 15 Old 09-20-2006, 10:50 AM
Clay Henry's Avatar
Quoted: 33 Post(s)
Wonder what they stuffed your seat with!?
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #7 of 15 Old 09-20-2006, 11:02 AM
josh_tn's Avatar
Its 3FTNW21S81MA#####
LOL, no telling. Wonder if its still there?
josh_tn is offline
post #8 of 15 Old 09-20-2006, 11:11 AM
Glenn M's Avatar
It sure sayes your truck is 2001 F-250 Crew cab 4x4 6.8 V10 built in Cuautitian, Mexico
Did you check the vin # on the truck itself? Sometimes things get misread.
Glenn
Glenn M is offline
post #9 of 15 Old 09-20-2006, 12:54 PM
josh_tn's Avatar
Those specs are all correct except for the engine. I'm at work now, but I'll check the number on the truck when I get home(its not my daily driver).
josh_tn is offline
post #10 of 15 Old 09-20-2006, 01:47 PM
josh_tn's Avatar
Well, I just got home and checked the truck. Turns out the VIN# on my insurance card is incorrect. I'm pretty sure that number came from the title so I'm guessing its incorrect too. Strange. Anyway, the only difference is the 8th and 9th positions so looks like it is a PSD afterall.
Card: 3FTNW21S81MA#####
Truck:3FTNW21F41MA#####
josh_tn is offline
