08+ Tailgate - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 21 Old 04-28-2011, 06:53 AM Thread Starter
RanchStroke's Avatar
08+ Tailgate
Does a tailgate off an 08+ superduty fit my 2000 F250? I replaced my mirrors with 08's and just had to slightly modify them but fit perfect.
2006 F250 Kingranch CC 4X4- Totaled 4/28/15 RIP
2012 F250 Kingranch CC FX4- Stock
2000 F250 XLT SC 4X4- FF Stage 1 Injectors, 38R and WW2, Swamps IDM, 6 pos chip from Tony at TDP, CTS Gauges, 4'' MBRP, S&B intake, 20'' Fuel's-305 Dura Grapplers, Smoked Recon light's, HID'S 5K, Ranch hand bumpers
RanchStroke is offline
post #2 of 21 Old 04-28-2011, 06:55 AM
Big Tone's Avatar
Quoted: 2 Post(s)
Yes, I have an 08 gate on an 04.
All you have to do is change the hinge bracket on the pasanger side of the bed.
Big Tone is offline
post #3 of 21 Old 04-28-2011, 07:00 AM
03Powerstroker6.0's Avatar
driver side.
03 F350 Lariat CC LB 4x4,
straight Pipe 4" exhaust 6" tip
3" front lift
5100's bilstiens
high idle mod
Sct Gearhead tuned,
EGR deleted
trans,fp, boost, egt, ect, eot gauges
vgt switch
2low Switch
Zoodad
315/75/16 baja claw
Custom trac bars
coolent filter
ccv mod
arp studs by me
afe stg 2
fuel bb mod
Hids
Smoked LED tails/3rd
Harley headlights
Smoked led tail lights
08 T gate
Upgraded banjo bolts
2 12" subs/6x8 infinity speakers
JD cool Gaurd II coolent
03Powerstroker6.0 is offline
post #4 of 21 Old 04-28-2011, 11:22 AM
Where can I find an 08 tailgate at a decent price?
Skew12 is offline
post #5 of 21 Old 04-28-2011, 12:04 PM
DieselheadJake's Avatar
DieselheadJake is offline
post #6 of 21 Old 04-28-2011, 05:26 PM
Big Tone's Avatar
Quoted: 2 Post(s)
Originally Posted by 03Powerstroker6.0 View Post
driver side.
I believe your right, its been a while
Big Tone is offline
post #7 of 21 Old 04-28-2011, 06:02 PM
Cuzmail's Avatar
Not to be the search nazi, cause I really hate that chit when others say it
I have posted the driver's part number in a previous thread. It is a simple bolt on.
You don't need the hinge if you remove the torsion rod on the '08 and up tail gate.
Shawn
'05 F250 KR CC SWB
Mini Maxx
4" SS turbo back
AFE Stage II
EGR bypassed
Ravelco
Viper 5901
Train horns - of course !
Tool box, interior lights, & metal bed cover combo
'10 Tailgate with step
'08 Tail lights
'11 Rear bumper
Classic quote by Snake "Both of you should sell your trucks and buy imports with lots of stickers, big fart can mufflers, and a rear wing as tall as you can find. You'll fit in well with that crowd."
Cuzmail is offline
post #8 of 21 Old 04-28-2011, 06:19 PM
what would be a good price for one?
ms2004F-250 is offline
post #9 of 21 Old 04-29-2011, 09:47 PM
ScottyP5947's Avatar
Quoted: 18 Post(s)
I just did this job and the t-50 torx bolts are installed with locktite. I was swapping between two trucks, so I had double the work.
They were a bear to get out. I worked them back and forth with some pb blaster but heat would have helped a lot.
I have heard prices vary if you have the step included or not. 250-500 bucks from what I have seen.
Scott
2000 XLT F-250 7.3 Crew Cab Auto w/Transgo shift kit 193K mi
4" MBRP turbo back exhaust w/muffler
PHP TS chip - 65 tow/80DD/120 race
Stancor relay
Wicked wheel 2 + non EBPV pedestal + bellowed up pipes
Broken-into door lock mod
6637 filter
285/75/16 Hankook ATM's
2" Rough Country add a leafs all around
In the Driveway:
2000
, chipped! (For the wife) SOLD!
1995 Ford Mustang 3.8 (
2016 Chevy Silverado 2500 gasser
ScottyP5947 is offline
post #10 of 21 Old 09-24-2015, 05:50 PM
Fred Swanson's Avatar
Will the latch assy out of my 2000 work with the 2008 and up tailgates and the square 2008 handle? also will the top plastic molding from the 2000 work or do I need to get a 2008 and up molding, Thanks for any info....
1995 PSD F-350 Crew Cab Dually....Sold
2000 PSD Crew Cab F-250 4x4
285 Geolanders
EBP sensor and tube clean
Badwin air filter #PA2818
Replaced carrier beariing
Replaced water pump
Repalced ICP and CPS
Straight Pipe
Gauges and A pillar pod
Superchips Flashpaq #1805
Foil Delete Mod
Replaced Glow Plugs ZD11's
Fred Swanson is offline
