Lost steering and brakes - wth - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 11 Old 12-11-2019, 08:07 AM Thread Starter
Quoted: 115 Post(s)
Backing into my driveway I heard something then I lost my power steering and brakes. Red fluid everywhere. There is no fluid in the power steering pump but the brake fluid is full. I'm looking everywhere. I don't see any hoses disconnected. The hose from the up to the brakes is in tact. I'm guessing it uses power steering fluid to operate the brakes.
It hasn't been making any noises or anything. I just installed a Hydra chip but I am assuming these are unrelated.
The wheel on the pump isn't loose. The fluid seems to be from the pump but I can't see where.
Any advice before I take it to the shop? Do I need towed?
Sent from my Nexus 6P using Tapatalk
guitarnut is offline
post #2 of 11 Old 12-11-2019, 08:15 AM
doubleslottedflaps's Avatar
Quoted: 190 Post(s)
something blew and spewed the fluid
NOTNOW > 2001 F350 CCLB DRW SCHTICK SHHHIFTER
WONTON > 2002 F350 CCLB DRW OTTOMATIC
FTCOBRA > 2006 F350 CCLB DRW SCHTICK SHHHIFTER
doubleslottedflaps is offline
post #3 of 11 Old 12-11-2019, 08:16 AM Thread Starter
Quoted: 115 Post(s)
Yes. I realize this.
post #4 of 11 Old 12-11-2019, 08:21 AM
Quoted: 471 Post(s)
Garage
Yeah, the steering pump supplies pressure for steering and brakes
Likely the fitting where the pressure hose attaches to the pump(swivel fitting) but could be anywhere along that hose
Running the pump without oil will damage it -- so, yeah need a flatbed unless you replace the hose your self
Personally, I would take the opportunity to learn more about the truck -- and replace the hose in the driveway
Remove the front tire(jack stand for safety) , remove the fender liner for easier access to the pump lines
an hour or so and save the rest of the money you would have spent at the shop, for beer
18M_RWR likes this.
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is online now
post #5 of 11 Old 12-11-2019, 10:05 AM
SuperCrutyPS's Avatar
Quoted: 649 Post(s)
Garage
I recently had to have a hose replaced. Mine split enough to let fluid out over time, but I was filling it up everyday before getting it fixed so I was headed that way.
Start by checking the hose that goes from the pump to the Hydro-boost unit and the one that goes from HB unit to the steering box.
Then get some cleaner or a pressure washer - the red stuff does make a mess!
Darryl | Owner/Operator
Truck | 2001 F350 7.3L CCLB |
5th Wheel |
Proud US Navy Veteran | '76-'80 -
- 'Gator Navy
SuperCrutyPS is offline
post #6 of 11 Old 12-11-2019, 03:22 PM
dieselcrawler's Avatar
Quoted: 35 Post(s)
Garage
It's not easy but the hoses can be replaced without removing the inner fender, but you have to pull the intercooler tube... good time to clean the boots, and the foil sound deadener is likely soaked with steering fluid too, good time to remove that if you're inclined.
SuperCrutyPS and Hydro like this.
Greg
E'99 F250 extcab, S/Bed 223k. W/ 378k mile 7.3 motor installed at 212k
'00 Excursion Limited, 7.3PSD 308k
'02 F250 extcab, L/bed, 340k. 7.3L 6spd 4x4
'00 F250 CCSB, 5.4 gasser 235k
200? F250 SuperDuperDuty Extended crew cab short bed project in process w/ 3rd row seating. 7.3L, 6spd, 4x4
Semper Paratus
dieselcrawler is offline
post #7 of 11 Old 12-12-2019, 12:13 AM Thread Starter
Quoted: 115 Post(s)
Thanks so much for the advice. It's that steel fitting hose on the side. Hose and fitting seem fine. I don't feel like ripping everything apart. The auto store is 20 minutes away (one way) so I'd spend all day screwing with this. AAA towed me. I'll pay the shop to save myself the time and frustrations. The fitting came loose for a reason and my guess is that the threads on the pump are toasted. Unlike most posters, I'll post an update when I get her home.
This damn thing is becoming the money pit.
post #8 of 11 Old 12-12-2019, 06:47 AM
Quoted: 25 Post(s)
Welcome to the world of 7.3 - they do like to be fed.
01 F350 Dually 4x2 Long 7.3 - Manual - Mods: Hutch, Harpoon, Remote Fuel Filter, Dual Disk Southbend Clutch, Heim Joint, Gauges, Disabler, 08 Tail w/Camera, Pioneer Head w/Lockpick, Exhaust Brake, Rails, Air Raid, 06 Headlights, 50 cent, Air Bags, Hydra, Riff Raff Boots, AFE Blade Runner intake, CNC HPOP lines, Banks Monster Turbo Back 4 inch, Billet Aluminum Plenums, ATS Boost Fooler, AFE Wastegate, Bellowed Up Pipes, Garret Powermax Ball Bearing Turbo, 160/30's, Moroso Pan, CnC 4 Fuel X-Over, CxRacing Intercooler Pipes. Coming next: ?? Wish list: Train horn, 4x4 conversion.
06 Mustang GT - GCC spec (Infidels May be closer than they appear) (SOLD)
16 Sonata Hybrid - Gas saver
Arizona_SVO is offline
post #9 of 11 Old 12-19-2019, 10:10 AM Thread Starter
Quoted: 115 Post(s)
New pump and high pressure hoses. $700 poorer and the money pit is back on the road. Brakes actually feel better now. Not $700 better.
Shoulda bought the new ram last year when they offered me 8000 in trade
post #10 of 11 Old 12-19-2019, 10:40 AM
jman37's Avatar
Quoted: 388 Post(s)
Garage
So the pump was bad too?
'11 F-250 RCLB FX4 6.7 - Deleted, SCT GTX - Tyrant tuned, Duratrac's on Moto Metal 962's - Sold
'17 Grand Cherokee SRT - Stock
'97 SVT Cobra - Few things
'88 Mustang LX - Built 306ci, built AOD, 4.10's - Sold
'06 F-350 ECSB Lariat FX4 6.0 - Studded, deleted etc..-Sold
'07 F-250 XLT ECSB 4x4 6.0 - Studded, deleted etc..-Totaled
jman37 is online now
