White Smoke Rough Idle - Ford Powerstroke Diesel Forum
 2Likes
  • 2 Post By Widowson2
post #1 of 9 Old 12-09-2019, 10:55 AM Thread Starter
retaliashun's Avatar
Quoted: 65 Post(s)
Garage
Was about to run errands and when starting truck was a bit sluggish. Outside temp was around 70į though it's been dropping down into the low 50s/40s overnight. Didn't have block heater plugged in.
When finally started was running a little rough and a lot of white smoke coming out of the tail pipe. Turned it off and plugged in the block heater for a couple hours, cranked right up but still a lot of white smoke and a rough idle. Smoke is really eye stinging. At idle it comes out the tail pipe in puffs like my truck is sending out smoke signals
I'm assuming injectors or injector o-rings. Buzz test was ok. Just replaced injector #5 a couple months ago.
Anything else I should check to rule out besides the Injectors. Any way to tell if it's just one injector or if I"m gonna take the VC off just do them all, with them being this old and with this many miles on them.
'99
F250 SD 7.3L 260k Miles
Edge CTS 2, Crown Performance Brake Lines, 230A Leece-Neville Alt
retaliashun is offline
post #2 of 9 Old 12-09-2019, 11:29 AM
Quoted: 482 Post(s)
Garage
The engine crank over evenly? no skips or humps?
if the smoke out the exhaust smells like raw fuel, then it is a compression problem
Good on you for testing with the block heater -- but should never need that in normal circumstances in Texas
Glow plugs should do all you will need -- are they working?
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #3 of 9 Old 12-09-2019, 11:42 AM Thread Starter
Quoted: 65 Post(s)
Garage
after being on the block heater it did. initually was a slow sluggish start. noticed last year during winter weather, even in texas I would need the block heater when temps start hitting 40s
replaced glow plugs at 3, 5, and 7 when injector 5 was replaced. glow plug on number 1 broke when being replaced, broke off tip still stuck in there. shop wanted 1800 to pull the heads, which i didn't have.
was planning on doing the other bank glow plugs, but just hadn't gotten around to it yet
'99
post #4 of 9 Old 12-09-2019, 02:45 PM
7.3_TurboDiesel's Avatar
Quoted: 128 Post(s)
Unplug the big square wire connection with the 10mm bolt holding it together and crank the truck. Listen to the rpms, this will tell you if you have a compression problem because the injectors wonít be firing
Sent from my iPhone using Tapatalk
7.3_TurboDiesel is offline
post #5 of 9 Old 12-09-2019, 03:38 PM Thread Starter
Quoted: 65 Post(s)
Garage
Sorry, which wire are you meaning? The connection to the uvch? And what should I expect the rpms to be doing?
post #6 of 9 Old 12-09-2019, 07:07 PM
Widowson2's Avatar
Quoted: 4 Post(s)
He means the connector over the driver side valve cover. Its in a metal bracket. Plug is squate and has a 10mm bolt in it. See pic
Widowson2 is offline
post #7 of 9 Old 12-09-2019, 08:00 PM
Quoted: 128 Post(s)
Yes thatís the connector meant, sorry I didnít clarify. I was preoccupied when I typed that
post #8 of 9 Old 12-10-2019, 02:11 PM
greenskeeper's Avatar
Quoted: 300 Post(s)
Does the smoke clear up once the engine is warm? If so it could be glow plugs, relay, or even armature clearance issues.
Gunga galunga...gunga -- gunga galunga.
97 F-250 CC 4x4 7.3L PSD E4OD 203K all original
99 F-250 CC 4x4 7.3L PSD ZF6 253K all original
greenskeeper is offline
post #9 of 9 Old 12-11-2019, 01:08 AM Thread Starter
Quoted: 65 Post(s)
Garage
No. Smoke never stopped once engine is at temp
'99
