New to me 1999 F350, got a few questions. - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 5 Old 12-04-2019, 06:03 PM Thread Starter
Been a long time since I've posted. I just bought a one owner stone stock 1999, F350, CC, Dually, 6spd, 4x4 with 160K miles. I already have an early build 99 250 automatic that I have done a few things to, Hydra, cold air intake, MBRP exhaust, Transgo kit, billet convertor, A pillar gauges etc... I'd like to follow the same path for mods but this is a manual truck and I wonder if that changes things for mods? Also, what gauges in the A pillar pod. I have EGT, Trans and boost in the 250 but what three do I need in the 350, EGT, Boost and ????
I already ordered the Hydra and MBRP exhaust from CNC Fabrication on Cyber Monday.
E99 (11/98) F250 SC LWB 4x4, 4" MBRP turbo back, A pillar pod w/Autometer Phantom EGT, Boost and Trans temp gauges, White face gauges in dash, PHP Hydra tuned, Transgo shift kit, S&B Cold Air Intake
Msnglinc is offline
post #2 of 5 Old 12-04-2019, 06:37 PM
7.3_TurboDiesel's Avatar
Quoted: 127 Post(s)
The mods will be the same. Get a fuel pressure gauge instead of a trans temp gauge on the manual truck
Sent from my iPhone using Tapatalk
7.3_TurboDiesel is online now
post #3 of 5 Old 12-04-2019, 06:41 PM Thread Starter
Thanks, HPOP or fuel rail?
Msnglinc is offline
post #4 of 5 Old 12-04-2019, 06:59 PM
Quoted: 127 Post(s)
People normally put them on the fuel bowl
The only reason I say to swap trans temp for fuel pressure is because trans temp isnít an issue in with a manual trans, and fuel pressure is worth watching especially if you are gonna do performance mods
post #5 of 5 Old 12-05-2019, 08:32 AM
Corey@CNCFAB's Avatar
Quoted: 1459 Post(s)
Feedback Score: 4 reviews
If you plan on wanting to watch more vitals, then I would suggest the EDGE Insight monitors. Quality Isspro or Autometer are more than the Insight CTS2. Easier to install with no wire splicing and you can see alot more sensors. If you add the Competition kit, then that will get you EGT's, fuel, and coolant. Trans temp is through the PCM. They are 10% off right now.
https://cncfab.us/i-30497723-edge-pr...sor-98617.html
https://cncfab.us/i-30497709-edge-pr...cle-84130.html
JustinOOO9 likes this.
[SIZE="3"]For all your ford powerstroke needs. If you dont see what you are looking for on the website, please use the contact page and shoot us a message or
Part numbers will help alot too if they are not on our site.
