Bed Swap maintance - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Billy231
post #1 of 9 Old 12-03-2019, 04:22 PM Thread Starter
Garage
Bed Swap maintance
Hello Everyone, I purchased my 7.3 with a fancy utility bed on it and am going to swap back to the stock 6ft bed. Any maintenance or things I should do while the bed is off ? I am planning on changing the fuel sending unit filter thats in the tank. Should I clean the tank out ?
The truck is an 2002 f250 7.3 4x4 just about to hit 200k.
Thanks for the advice!
Green73 is offline
post #2 of 9 Old 12-03-2019, 05:02 PM
Widowson2's Avatar
Quoted: 4 Post(s)
I would do the Hutch mode while you in the tank. Your already there
Widowson2 is offline
post #3 of 9 Old 12-03-2019, 05:46 PM
dieselcrawler's Avatar
Quoted: 35 Post(s)
Garage
Clean/paint the frame...
Greg
E'99 F250 extcab, S/Bed 223k. W/ 378k mile 7.3 motor installed at 212k
'00 Excursion Limited, 7.3PSD 308k
'02 F250 extcab, L/bed, 340k. 7.3L 6spd 4x4
'00 F250 CCSB, 5.4 gasser 235k
200? F250 SuperDuperDuty Extended crew cab short bed project in process w/ 3rd row seating. 7.3L, 6spd, 4x4
Semper Paratus
dieselcrawler is offline
post #4 of 9 Old 12-03-2019, 06:57 PM
7.3_TurboDiesel's Avatar
Quoted: 128 Post(s)
As stated, I’d clean up and paint the frame, delete the in tank screens all together (check on condition of the tank inside) and put a filter right before the pump spliced into that short rubber line. I bought a filter for $20 from vac motion, I can post the link if you want. Much better setup than factory
Sent from my iPhone using Tapatalk
7.3_TurboDiesel is offline
post #5 of 9 Old 12-04-2019, 11:22 AM
mike_hurd2000's Avatar
Quoted: 28 Post(s)
Hi if you have the link that be great and pictures? Thanks.
mike_hurd2000 is offline
post #6 of 9 Old 12-04-2019, 11:44 AM Thread Starter
Garage
I have never heard of the Hutch Mod (just got the truck a couple months ago) I will look into it, thank you.
I will definitely be painting the entire rear end !
yes please post a link for the filter delete and if you have them post some pictures of the installation.
Thank you all for your help!
Green73 is offline
post #7 of 9 Old 12-04-2019, 12:23 PM
SuperCrutyPS's Avatar
Quoted: 649 Post(s)
Garage
For easy reference, here is a thread from here containing a video about both the Hutch and Harpoon mods.
Hutch Mod Filtering
While the bed is off, DEFINITELY everything above. My add would be to check anything that would difficult to do with the bed is on. Spare tire & wench, exhaust pipe hangers, U-joints @ the diff, check to see if the diff is leaking, "on-axle" brake lines, shocks/mounts, etc. Just my 1.5 cents worth (adjusted for inflation )
Darryl | Owner/Operator
Truck | 2001 F350 7.3L CCLB |
5th Wheel |
Proud US Navy Veteran | '76-'80 -
- 'Gator Navy
SuperCrutyPS is online now
post #8 of 9 Old 12-04-2019, 02:16 PM
Quoted: 128 Post(s)
Bed Swap maintance
3/8" Hose Barb In-Line Strainer with 50 mesh stainless steel filter screen https://www.amazon.com/dp/B00CH2JSIY..._u-c6DbEV0XZAG
This is what I got. It is about 300 micron, which is much larger than what people typically use. They offer one with a 170 micron (80 mesh) rating.
Many people put a tiny 2 micron pre pump, but the pump does not need that fine of a filter to keep it safe, and a filter that fine can actually starve it. As long as you keep big chunks out of it, it’ll be fine. (Many people delete the in tank screens and don’t run a pre pump filter at all and don’t have issues)
If you want the 170 micron version, go to “VacMotion.com” the filter is considered the “mini” series and has a 3/8” barb on each end
post #9 of 9 Old 12-05-2019, 09:58 PM
Billy231's Avatar
Quoted: 62 Post(s)
Garage
Bed Swap maintance
As stated with others posts which are all good especially brake lines. Be sure to check the steel line behind fuel tank that cannot be seen easily nor accessed when is fails. Change it now with copper line/fittings and be done with it.
Also check tank straps.
7.3_TurboDiesel likes this.
Billy231 is offline
