2001 f-350 low mpg researched - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-01-2019, 04:35 PM Thread Starter
Good afternoon everyone i have a 01 f-350 4x4 3.73 crew cab long bed lifted 4" on 315s
The problem i have had for a while is getting low mpg I started with 6 MPG not towing anything. I replaced the brakes front and rear because they were dragging and numerous of other parts including glow plugs, injector harnesses, new manifolds, up pipes, wicked wheel, atp turbo housing, wastegate, ebp line and sensor, map sensor, tank filters and numerous other maintenance items. With all the upgrades and replacement parts I only increased to 7.5 mpg which still sucks.
Towing I can get 6 mpg max
Hubs seem okay transmission was rebuilt before I purchased it. Doesnt seem to lack power
Doesnt overheat trans temps are good and egts stay under 1000 when towing
Not sure what else to check other than replacing the injectors. Does anyone have any ideas?
Thank you
rt85corona is offline
post #2 of 8 Old 12-01-2019, 04:54 PM
Quoted: 115 Post(s)
Are you sure you are calculating correctly? Are you blowing smoke? Possibly leaking? Idling a lot? I'd look for a leak personally.
Sent from my Nexus 6P using Tapatalk
guitarnut is offline
post #3 of 8 Old 12-01-2019, 05:09 PM Thread Starter
I tested multiple times with fuel tracking app and manually tracking I same results.
No visible fuel leaks when idling and I dont idle for long either.
post #4 of 8 Old 12-01-2019, 05:33 PM Thread Starter
265k miles on motor
post #5 of 8 Old 12-01-2019, 09:22 PM
Turbostang500's Avatar
Quoted: 14 Post(s)
My first thought is the speedometer is not showing correct speed. If so, due to the 35" tires, this will also affect the odometer and from my experience, about 10-11%. If I am correct, try multiplying your mileage by 1.10 and use the new calculated number for fuel mileage.
Besides that, the driver makes the largest difference in fuel economy. Try driving slower than your grandpa for a whole tank of fuel. It is darn near impossible but usually reveals results. Also, longer drives between 45-60 mph will net the best economy. Much below or above and economy seemed to start fading. Above 70 mph and it down right starts to drop, quickly.
I have a SCSB 4x4 with 33's and 4.30 gears. I average 13.5 mpg with 440k on the engine. Just installed new injectors without much change but the 4.30 gear happened at the same time. I believe I will be putting 3.73's in soon.
Turbostang500 is offline
post #6 of 8 Old 12-02-2019, 01:57 AM
Quoted: 115 Post(s)
That is what I meant by miscalculation. I have 235k and get 14-17mpg depending on what I am doing. No way he is at 6 without a fuel leak, hot tune, or a miscalculation (such as misfunctioning odomoter).
post #7 of 8 Old 12-10-2019, 12:20 PM
Quoted: 115 Post(s)
Why do people just drop off and not update the forum?
post #8 of 8 Old 12-11-2019, 04:36 AM
Quoted: 14 Post(s)
Frustrating....
