Php Hydra chip - Page 4 - Ford Powerstroke Diesel Forum
 5Likes
post #31 of 57 Old 11-27-2019, 02:11 PM
doubleslottedflaps's Avatar
Quoted: 190 Post(s)
Originally Posted by 00t444e View Post
It's heat over time that kills engines, gauges would be less important for drag racing since your not running it that hot for very long. You would be surprised how hot your EGTs can get on a 120 HP setting.
i dont drag race i road race obviously you dont know enough about engines. i also worked as an auto mechanic for 10 years.
also tell the op what gauge readings would show danger. someone that doesnt know how to read gauges will not know when to back off the gas.
NOTNOW > 2001 F350 CCLB DRW SCHTICK SHHHIFTER
WONTON > 2002 F350 CCLB DRW OTTOMATIC
FTCOBRA > 2006 F350 CCLB DRW SCHTICK SHHHIFTER
doubleslottedflaps is offline
post #32 of 57 Old 11-27-2019, 02:54 PM
00t444e's Avatar
Quoted: 612 Post(s)
You road race a diesel truck? That's the first I have heard of that. Obviously you don't know much about diesel engines or you would know why having boost and egt gauges is important and not be giving out bad information. A transmission temp gauge is good to have on any automatic behind a diesel or gas engine. An egt gauge is important because if you egts run high for extended periods of time you can burn up valves, melt pistons, or damage your turbo. 1200 degrees is the safe limit for egts, and back when I had stock the injectors and turbo I could hit over 1200 degrees going uphill unloaded in the PHP 60 hp eco tune, in the higher hp tunes I can get to 1200* even quicker. Boost is good to have to make sure your truck is running right and doesn't have any boost leaks, a stock 7.3 will max out at 17-19 psi, and about 30 psi on a hot tune, which is also about the limit for your stock turbo, it will also let you see if you have turbo surge which is what killed my factory turbo.
00 f250 ext. cab, lb, 4x4, 170,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, KC 300x 63/73/.84 turbo, PHP Hydra, Riff Raff frx,, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, Edge CS2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #33 of 57 Old 11-27-2019, 07:11 PM
Quoted: 4 Post(s)
Been running an sct canned tines for years, want to move to Hydra. What's their website that has the Black Friday deal??
Originally Posted by hansel View Post
Running the PHP Hydra on both trucks (F-250 CCSRW 4X4, F-350 CCDRW 2X4) nothing but standard mods on the trucks, intakes, exhaust, but the F-350 does have a KC turbo but I'm still on stock injectors. The standard tunes from Bill (PHP) work just fine, some people having shifting problems but a custom valve body usually cures this issue. If you get a Hydra I suggest some gauges so you can monitor EGT's, etc...... I believe they are having a Black Friday sale on the Hydra you might want to check out their web site.
a11m1ghty is offline
post #34 of 57 Old 11-27-2019, 07:59 PM
hansel's Avatar
Quoted: 383 Post(s)
I checked their web page, and nothing. They announced something about black Friday on facebook my mistake.
2001 7.3L CCSRW 4X4
2003 7.3L CCDRW
S&B intake, 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission. Edge SCT2
PHP Hydra chip's
2015 Heartland Prowler
hansel is offline
post #35 of 57 Old 11-27-2019, 07:59 PM
Corey@CNCFAB's Avatar
Quoted: 1459 Post(s)
Feedback Score: 4 reviews
The Hydra chips will soon have a $25 rebate.
https://cncfab.us/i-30498022-power-h...php-hydra.html
www.cncfab.us
[SIZE="3"]For all your ford powerstroke needs. If you dont see what you are looking for on the website, please use the contact page and shoot us a message or
Part numbers will help alot too if they are not on our site.
post #36 of 57 Old 11-27-2019, 08:03 PM
Quoted: 190 Post(s)
I roadrace a 65 mustang
post #37 of 57 Old 11-28-2019, 12:59 AM Thread Starter
Quoted: 115 Post(s)
Originally Posted by JustinOOO9 View Post
This whole thread is
The OP has asked in multiple threads the same question and he keeps getting the same answer but continues to ask about the hydra... Anyone who has done 5 minutes of research would learn the following:
Currently the Hydra is generally seen as second to none for the 7.3l platform and its been ran for 100,000s miles on 100,000s of vehicles with no reduction in longevity specifically related to the chip... Its usually a combination of injectors, turbos, heavy ft and sometimes improper tunes from some of these Facebook fanboy clubs.
Not sure why you want to break my stones for asking questions. Irrc, I first asked about the tps when someone mentioned the Hydra, then I asked about tps vs Hydra and based off that I decided if I do it Hydra is the way to go so now I am asking specifically about the Hydra. IMHO it shows a progression (tps, tps vs Hydra, Hydra) so in my mind, this board has done for me exactly what it is designed to do.
Thanks everyone for the responses. I hoped there would be more consensus.
Sent from my Nexus 6P using Tapatalk
guitarnut is offline
post #38 of 57 Old 11-28-2019, 10:54 AM
Quoted: 4 Post(s)
Thanks Corey. When does the TC lock on these stock canned tunes? Will I have to order custom tunes to lock the TC?
www.cncfab.us
post #39 of 57 Old 11-28-2019, 01:47 PM
JustinOOO9's Avatar
Quoted: 1679 Post(s)
Garage
Feedback Score: 3 reviews
This whole thread is <img src="https://www.powerstroke.org/forum/images/smilies/bdh.gif" border="0" alt="" title="Bdh" class="inlineimg" />
Lol not bustin stones you’d know if I were. Just pointing out that if you had used the search function on google and this forum you’d see exactly what everyone was saying here. I would have kept my fat mouth shut but you asked multiple times in different threads if you should.
Trust me I get it you like your truck and want it to last but want some oomph. we like ours and want the same (usually).
When you install the hydra keep us updated on what tunes you like and if anything comes up that is odd.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is offline
post #40 of 57 Old 11-30-2019, 06:35 PM
All depends on how heavy your foot is.
www.cncfab.us
