flex plate removal - how to hold crank? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-22-2019, 04:50 AM Thread Starter
greenskeeper's Avatar
Quoted: 292 Post(s)
Got the transmission/t-case away from the flex plate enough to start removal of the bolts. What's the best way to hold the crank stationary while I back off the bolts?
greenskeeper is offline
post #2 of 3 Old 09-22-2019, 05:34 AM
00t444e's Avatar
Quoted: 564 Post(s)
They make a tool to hold the flexplate, or you can wedge a screwdriver or prybar in there.
00 f250 ext. cab, lb, 4x4, 158,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #3 of 3 Old 09-22-2019, 05:35 AM Thread Starter
Quoted: 292 Post(s)
Thanks. Ended up putting a screw driver between the frame and alignment pin wedged on one of the teeth.
