TC, flex plate, or transmission? - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By greenskeeper
post #1 of 8 Old Yesterday, 04:31 AM Thread Starter
greenskeeper's Avatar
Quoted: 291 Post(s)
This is on my 97, put it in here for more traffic....move it if you want mods.
Started out with a grinding noise only in P R D 2 or 1. No noise in neutral.
Now I've got a horribly loud grinding noise in all gears, so loud that I am thinking it is eternal to the transmission or torque converter. So I am thinking flex plate?
The truck drives and shifts fine, although I'm not driving it anymore until I figure out what that noise is.
If I pull the inspection cover will I be able to see most of the flex plate while rotating the engine by hand?
greenskeeper is offline
post #2 of 8 Old Yesterday, 06:16 AM Thread Starter
Quoted: 291 Post(s)
video from this morning with inspection cover removed
post #3 of 8 Old Yesterday, 08:24 AM
7.3_TurboDiesel's Avatar
Quoted: 95 Post(s)
Maybe itís just the video quality, but the flexplate looks like itís wobbling to me. Try and look straight up near where the bolts are and see if itís broken. Thatís where they usually fail
Sent from my iPhone using Tapatalk
7.3_TurboDiesel is online now
post #4 of 8 Old Yesterday, 12:00 PM Thread Starter
Quoted: 291 Post(s)
There is a collar or spacer between the block and the flex plate that is hiding the bolts. I turned the flex plate by hand and there are no cracks extending to where I can see.
post #5 of 8 Old Yesterday, 02:30 PM Thread Starter
Quoted: 291 Post(s)
I pulled the truck into the garage, as soon as I gave it any pedal the noise went away. Almost certain it's going to be the flex plate.
post #6 of 8 Old Today, 05:38 AM Thread Starter
Quoted: 291 Post(s)
cracked all the way around....going to replace with OEM ford if the part is still available.
Name:	flex plate.jpg
7.3_TurboDiesel likes this.
post #7 of 8 Old Today, 08:02 AM
Jjorgis5569's Avatar
Quoted: 55 Post(s)
Interesting, thanks for sharing. Iíve only had one personal experience with a cracked flex plate, and it sounded like a rod knock.
Jjorgis5569 is offline
post #8 of 8 Old Today, 03:06 PM Thread Starter
Quoted: 291 Post(s)
Same here...sounded like the engine was going to blow until I gave it a little pedal....then quite.
