2008 Mirror Upgrade Heat Function Wiring - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Hydro
post #1 of 4 Old 09-17-2019, 08:01 PM Thread Starter
Quoted: 3 Post(s)
Hello, I recently upgraded to power 2008 mirrors with heat and lights. The truck had none of this from the factory so I had to wire everything myself. I have not wired the heat function yet. I do not want to hard wire the heat to be on at all times, and I do not want to install another switch.
I was wondering if it would be possible to tie them into the climate control wiring so the mirror heat would be powered when my defroster is turned on on the dash. Is this possible? Has anyone had any experience doing this?
kevaldridge96 is offline
post #2 of 4 Old 09-17-2019, 08:10 PM
Quoted: 358 Post(s)
Garage
No I have not done this -- was thinking of a way tho
You could attach a micro switch to the defrost door actuator and use that to switch a relay connected to the mirror heat
doubleslottedflaps likes this.
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #3 of 4 Old 09-17-2019, 09:34 PM Thread Starter
Quoted: 3 Post(s)
Thanks for the reply, what exactly is a micro switch?
Thanks!
post #4 of 4 Old 09-18-2019, 06:13 AM
Quoted: 12 Post(s)
Micro switches are exactly what the name implies - they are rather small switches used in all kinds of things where space is a premium. You can find them on Amazon or any retail electronics store. They usually have 3 leads - a common, a NO, and a NC - when the switch is activated, the NO closes and the NC opens. You probably do *not* want to wire the heat lead directly to that - rather have it power a relay that sends power to the mirrors. You'll probably overload the switch and burn it fast.
They are notorious for breaking the actuator arm off of them.
Arizona_SVO is online now
Tags
deforst , heat , mirror , upgrade , wiring
