Heater Hose Replacement Advice - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By DaveP.
  • 1 Post By Arizona_SVO
post #1 of 8 Old 09-04-2019, 06:15 AM Thread Starter
Rageous's Avatar
Arrow Heater Hose Replacement Advice
Hello
I have a 7.3 SD that I bought new in 2002 and now have 210,000 miles on it, and I think it's time to change the heater hoses. I am smelling coolant and cant find where it's leaking from as there is no obvious drip anywhere. I have replaced all radiator hoses and the deguise tank and hoses and cap. But still losing a fair amount of coolant (about a gallon in 400 miles). Any tips on the coolant loss and heater hose (brand, place to get hoses, ect.) replacement would be much appreciated.
Thanks
Rageous is offline
post #2 of 8 Old 09-04-2019, 06:50 AM
JustinOOO9's Avatar
Quoted: 1573 Post(s)
Garage
Feedback Score: 3 reviews
check the water pump and the outlet elbow on the bottom of the pump. There is either a straight or curved metal pipe bolted to the bottom of the pump (varies by year) with an o ring. Mine started leaking within a year or buying it. it was like $3 and good chance for me to drain the coolant/replace thermostat anyways.
Also are you seeing any whiter smoke than usual, sweet smelling exhaust vs the normal diesel stink?
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
Justin
JustinOOO9 is offline
post #3 of 8 Old 09-04-2019, 06:55 AM Thread Starter
Rageous's Avatar
No , no white smoke, diesel smell is normal.
Thanks
Rageous is offline
post #4 of 8 Old 09-04-2019, 07:05 AM
Quoted: 220 Post(s)
Removing the heater hose quick-connect couplers at the firewall is a Grade-A pain in the butt. I bought the removal tools (Lisle brand about $35.00) and the tools at least made it possible (no way without them), but was still fussy.
When a loss of coolant is not obvious, I use a pressure tester and pump up the system. It usually shows up then. If you can smell coolant, there's a leak somewhere. Could be the heater core, but there's usually steam on the windshield, and the smell is obvious. And even though these trucks are approaching 20 years old, I don't see much discussion about failed heater cores.
7.3_TurboDiesel likes this.
DaveP. is offline
post #5 of 8 Old 09-04-2019, 09:23 AM
Quoted: 13 Post(s)
I respectfully disagree with Dave about the tools necessary. I used a small flat-tip and it took about 2 or 3 minutes each hose.
I got replacement hoses and quick disconnects from rock-auto - work great. Took all of 20 minutes for everything.
If you get the quick disconnects first - it's really easy to see how they work and why a small flat tip does the trick.
DaveP. likes this.
Arizona_SVO is offline
post #6 of 8 Old 09-04-2019, 07:37 PM
GETFURIOUS's Avatar
Quoted: 233 Post(s)
GOT ANY PHOTOS OF THE QUICK DISCONNECT PARTS?....
NEVER MIND.....I FOUND THE PART AND PHOTO ON ROCKAUTO.COM.....
LOOKS EASY TO ME.....PUSH FORWARD.....SQUEEZE.....PULL OFF.....
Name:	2001 F-350 SUPERDUTY - HEATER HOSE CONNECTOR.jpg
GETFURIOUS is offline
post #7 of 8 Old 09-05-2019, 04:33 AM
Quoted: 13 Post(s)
Yep, thatís it. Also note if youíre careful, you can slice them off as long as you donít damage the tube it connects too. Itís a bit tricky. I cut my hoses short, wrenched these off with flattip and beat the hell out of them and then yanked the remnants off with plies/dykes to get ready for the new ones.
Originally I carefully saved my old ones to try and reuse. They leaked. Spend the 10 bucks and replace them... so much easier.
post #8 of 8 Old 09-05-2019, 02:31 PM
I recently had very similar issues with smelling coolant in the cab. I rarely smelled it outside. Truck had a new water pump and cooling system flush done within 15,000-20,000 miles. Cooling system was pressure tested both static and while running and it held pressure. Also had no noticeable coolant loss. I finally popped the lid off the heater core and it was slightly sticky along the bottom of half of the core. Passenger carpet was dry.
I ordered new heater hoses and heater core. Not having put them on yet, I took the truck to the store and on the way back turned A/C on and had slight smell of coolant like I had for weeks. Got home walked to passenger side of the truck and coolant was running out from the backside of the passenger fender.
If you are losing that much coolant it would be quite wet around those connections. Its going to be harder to see a small leak from the heater core draining out the evaporator drain. Of course, this doesn't mean you aren't burning it due to head gasket either.
I bought my hoses and core from Rockauto. Riffraff also carries the hoses for a good price. Careful with the two plastic heater hose connections that mount to the valve cover studs. Ford thinks they are made of gold as retail is around $60. Riffraff has them for $28.
Blue_Boosted_F250 is offline
