Fuel Filter ? - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By guitarnut
post #1 of 8 Old 08-24-2019, 05:42 PM Thread Starter
Quoted: 20 Post(s)
Fuel Filter ?
How often do you change your fuel filter and what brand do you use? Any tips for the change out?
bjblackout is offline
post #2 of 8 Old 08-24-2019, 07:18 PM
7.3_TurboDiesel's Avatar
Quoted: 134 Post(s)
I normally do around 15,000 miles, I use OEM but my dad has used aftermarket ones for years without issue. Post a pic of your fuel filter cap, we will tell you if itís OEM or not. OEM filters go with OEM caps, aftermarket filters come with different caps
Sent from my iPhone using Tapatalk
7.3_TurboDiesel is offline
post #3 of 8 Old 08-24-2019, 07:40 PM Thread Starter
Quoted: 20 Post(s)
This at the top would be OEM correct? I could use motorcraft filter? FD 4596??
post #4 of 8 Old 08-25-2019, 12:38 PM
Quoted: 134 Post(s)
Yes, thatís the factory cap
post #5 of 8 Old 08-25-2019, 03:36 PM
Buckhornmike's Avatar
Quoted: 40 Post(s)
Garage
Drain the bowl before you open it up, itís messy if you donít. If you stay with a stock filter a filter wrench is handy, using pliers will break it eventually, 16 bucks for the wrench I think
1999 F250 Supercrew LB
MBRP 4" straight pipe
S&B
PHP Hydra
Edge Insight CTS2
Sweet IH Steering knob (adds at least 1000HP)
"I have never bought anything with money. Everything I have was bought with pieces of time I sold from my life to a job that will never have paid enough when my time is up."
Spem Successus Alit
Buckhornmike is offline
post #6 of 8 Old 08-31-2019, 01:29 AM
Quoted: 122 Post(s)
Baldwin. Made in the USA. Mine didn't have the factory cap so I have to use one with the cap attached. I tried the one that you get at the auto store a couple times only to have it not seal right and either slow leak or in another case I had a geyser of diesel when I started. wife was happy about the mess in our driveway. Why the hell do they make driveways white.
Sent from my Nexus 6P using Tapatalk
7.3_TurboDiesel likes this.
guitarnut is offline
post #7 of 8 Old 08-31-2019, 03:17 AM Thread Starter
Quoted: 20 Post(s)
This is the lid I have. I have never changed the filter since the truck is new to me. I bought a motorcraft filter so I guess my next step is to take the lid off and make sure the lid is not part of my filter. If it is I need a new filter and not motorcraft. Is this correct??
post #8 of 8 Old 08-31-2019, 04:34 PM
Quoted: 134 Post(s)
Yes, you will need the motorcraft lid. As said above, they also seal much better than aftermarket ones. I fought with them multiple times
