Edge insight cts2 and fuel pressure - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 11 Old 08-16-2019, 08:26 PM Thread Starter
Vohs's Avatar
Quoted: 123 Post(s)
Garage
So I知 trying to figure out what parts and where to purchase the eas probe and required harness to monitor fuel pressure.
Also I知 guessing it installs by removing the plug on the fuel bowl?
I致e only seen a video for an analog gauge.
to conquer without risk is to triumph without glory.
Vohs is offline
post #2 of 11 Old 08-17-2019, 06:28 AM
voodooridr's Avatar
Quoted: 968 Post(s)
You'll need one of these https://edgeproducts.com/shop/eas-starter-kit-cable unless you already have the EGT probe with the starter kit
Then you'll need one of these https://edgeproducts.com/shop/eas-un...r-input-5-volt
And lastly, at least one of these https://edgeproducts.com/shop/eas-pr...psig-1-8in-npt
Their stuff isn't cheap but it should all play nicely with their monitors, someday I need to add fuel pressure and coolant pressure to my CTS2
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is offline
post #3 of 11 Old 08-17-2019, 09:07 AM
DieselDC
DieselDC's Avatar
Quoted: 682 Post(s)
I have both cts units (reader and the reader/tuner). Sometimes it won稚 turn off. At times I Get in and out of the truck 1-2mins and find out I gotta go and restart the truck - it freezes. So I got annoyed and both are unplugged. The best reader/tuner is my minimaxx. I just it to read only and it cycles on and off extremely fast and never froze once.
覧覧耀ignature覧覧
~Don稚 overthink something simple~
...:uptight people suck:...
Vohs likes this.
DieselDC is offline
post #4 of 11 Old 08-17-2019, 09:15 AM
Corey@CNCFAB's Avatar
Quoted: 1406 Post(s)
Feedback Score: 4 reviews
I've got everything you need in stock chief. Also depends on what you want to read, it may be less money to get the comp kit.
www.cncfab.us
SparkyF250 and Vohs like this.
[SIZE="3"]For all your ford powerstroke needs. If you dont see what you are looking for on the website, please use the contact page and shoot us a message or
Part numbers will help alot too if they are not on our site.
post #5 of 11 Old 08-17-2019, 02:19 PM Thread Starter
Vohs's Avatar
Quoted: 123 Post(s)
Garage
That痴 insane, that totals more then the entire monitor. Guess I won稚 be doing that anytime soon.
Vohs is offline
post #6 of 11 Old 08-17-2019, 02:25 PM Thread Starter
Vohs's Avatar
Quoted: 123 Post(s)
Garage
www.cncfab.us
All I知 looking to do is be able to monitor fuel pressure. I have three analog gauges. Trans temp, egt and boost. Plus I have the edge monitor.
The trans gauge is flickering and I believe a wire is bad so Now I知 thinking to pull it and replace with a fuel pressure gauge now that I知 seeing the cost of setting up and edge sensor and the Edge monitors the trans temp.
Vohs is offline
post #7 of 11 Old 08-17-2019, 02:26 PM
SparkyF250's Avatar
Quoted: 3258 Post(s)
Garage
Check @[email protected] , when I bought mine he had a package deal on the expansion stuff, pressure sensor & temp probe. Nice to actually see coolant temp on the 7.3. That's only if you're already running an Edge CTS / CTS2
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
SparkyF250 is offline
post #8 of 11 Old 08-17-2019, 02:28 PM Thread Starter
Vohs's Avatar
Quoted: 123 Post(s)
Garage
I致e got the edge cts2 Insight monitor and that痴 it.
Vohs is offline
post #9 of 11 Old 08-17-2019, 02:30 PM
SparkyF250's Avatar
Garage
email or PM Corey and see what he has. He's great to do business with and he knows the 7.3 as well as anyone on here.
Sparky
The Following User Says Thank You to SparkyF250 For This Useful Post:
Vohs (08-17-2019)
post #10 of 11 Old 08-17-2019, 03:21 PM Thread Starter
Vohs's Avatar
Quoted: 123 Post(s)
Garage
Thanks, I will once I muster up the courage to drop that cash for fuel pressure monitoring
Vohs is offline
