Tire recommendations 35/12.5/18 - Ford Powerstroke Diesel Forum
 5Likes
post #1 of 11 Old 08-16-2019, 10:59 AM Thread Starter
Vohs's Avatar
Quoted: 123 Post(s)
Garage
Gonna need some new tires here soon, just wanted to see what everyone has to say and get some opinions. Currently running toyo open country mtís. Is there a comparable tire thatís not 300$???
Thanks!
to conquer without risk is to triumph without glory.
Vohs is offline
post #2 of 11 Old 08-16-2019, 11:05 AM
voodooridr's Avatar
Quoted: 975 Post(s)
Loving my Ridge Grapplers but they're not cheap
Sent from my SM-G960U using Tapatalk
Vohs likes this.
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
35x12.5x18 Nitto Ridge Grapplers on Method MR309 wheels
KDD heads, ARP studs, BD exhaust manifolds, DieselSite up pipes, Mishimoto degas bottle
PHP Insight PRO
PHP Atlas 40 FICM tune
voodooridr is offline
post #3 of 11 Old 08-16-2019, 11:10 AM
White_Buffalo7.3's Avatar
Quoted: 187 Post(s)
Garage
depends whether you want at's ht's or mud tires ect. i run Bridge stone dueler ht 684. Really like the ride and the longevity.
White_Buffalo7.3 is offline
The Following User Says Thank You to White_Buffalo7.3 For This Useful Post:
Vohs (08-16-2019)
post #4 of 11 Old 08-16-2019, 11:13 AM Thread Starter
Vohs's Avatar
Quoted: 123 Post(s)
Garage
Longevity is key, but also trying to kill some road noise. The Toyoís arenít terrible but I notice them.
Vohs is offline
post #5 of 11 Old 08-16-2019, 11:19 AM
Quoted: 187 Post(s)
Garage
I have a wholesale account through work so i only paid 180 a piece for the Bridgestones. My dad got 88k out of his dueler alanzas. I'm shooting for 70+.
post #6 of 11 Old 08-16-2019, 11:42 AM
JustinOOO9's Avatar
Quoted: 1575 Post(s)
Garage
Feedback Score: 3 reviews
They aren't MT tires but BFGoodrich makes their All Terrain tire in a 35x12.5R18. I really like mine 99% of the time. They grab well in snow/ice, rain, and dry pavement, no sidewall roll or sway with a heavy 12k 5th wheel behind it, and tread life seems to be really good. gone through 3/32s tread in around 20k miles. I rotate every 5k and check air maybe 4-5 times a year. Honestly you're gonna have to just pick one. Research shows tires are love/hate no middle ground. I found people bashing the tire I run left and right, and then opposite. You'll see the same for every tire.
Pick a tire that meets your needs, check the pressure regularly and rotate regularly and that's all you can do.
p.s. when I say I like my BFG A/T's 99% I only dislike the gravel they pick up on gravel roads. I installed duraflap mud flaps and that basically eliminated the problem. I will be going with MT tire next just to be that guy hahaha.
Bfg, Cooper, Dean, Toyo, Yokohoma and a few more etc. stick with a big brand name and your usually gonna be just fine.
Vohs likes this.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
Justin
JustinOOO9 is offline
post #7 of 11 Old 08-16-2019, 11:50 AM Thread Starter
Vohs's Avatar
Quoted: 123 Post(s)
Garage
Thatís kinda my thoughts, but didnít know if Iím missing a unicorn out there. Haha thanks Justin.
Vohs is offline
post #8 of 11 Old 08-16-2019, 12:03 PM
voodooridr's Avatar
Quoted: 975 Post(s)
The Ridge Grapplers do pick up bigger rocks than the Grabber AT2s ever did
The Grapplers are just as quiet though
Look into dynabeads for balancing
Vohs likes this.
2004 F250 CCSB 4X4
4" Skyjacker lift
3:73 gears
PHP Insight PRO
post #9 of 11 Old 08-16-2019, 12:24 PM
DesertDiesel's Avatar
Quoted: 70 Post(s)
I'm running a no-name Radar Renegades MT. I had Toyo Mt's on my last 7.3. The renegades are significantly quieter. I have 16,000 miles on them and they're barely worn. I will with no doubt buy them again. 37x13.5x20
ID:	721877   Click image for larger version
Vohs likes this.
DesertDiesel is offline
post #10 of 11 Old 08-16-2019, 12:35 PM
Quoted: 70 Post(s)
There's a you tube video out there that rates the best budget Mt's you can watch. I think the Radars I have are $275 each. There are more than one unicorn out there.
