Steering Stabilizer ? - Page 2 - Ford Powerstroke Diesel Forum
 4Likes
post #11 of 22 Old 07-30-2019, 01:02 PM
Quoted: 115 Post(s)
Originally Posted by Horizon122 View Post
What does a lift kit have to do with it? I was asking if the brand of the steering stabilizer you had was a rough country, based on their mounting configuration it is known to make noise.
“What kit do you have” sounds like you’re asking about a lift KIT.
Sent from my iPhone using Tapatalk Pro
7.3_TurboDiesel likes this.
Jav_eee is online now
post #12 of 22 Old 07-30-2019, 05:37 PM Thread Starter
Quoted: 19 Post(s)
Originally Posted by DaveP. View Post
Check the metal lines for the power steering / hydroboost where they go by the LF shock tower for interference. Makes a clunk that one would swear is in the suspension, but it's not.
Someone mentioned "I-beam bushings". These would be on a 2WD truck. Most trucks on here are 4X4, but my point is that the two suspensions are different. Stating 4X4 or 2WD is helpful when discussing things where it makes a difference with diagnosis.
Your white steering stabilizer is probably a Rancho. The mounting methods for these Rancho kits leave much to be desired. Try taking it all off and driving it. I doubt you'll notice any difference without it other than if it IS the source of the clunk the clunk should be gone.
I ordered a new stabilizer so we shall see if I can get rid of this noise. Mine is a 4x4, sorry for not mentioning in the beginning.
bjblackout is offline
post #13 of 22 Old 07-31-2019, 06:23 PM
Sway bar links. Two (one on each side). 02 F350 SRW with exact same symptoms. Replaced both and problem was solved.
mustangea likes this.
Tph1956 is offline
post #14 of 22 Old 08-01-2019, 05:37 AM
Quoted: 9 Post(s)
Sway bar end links...had it happen in two of my trucks, it's an annoying noise and you think the trucks falling apart but those are a quick easy and inexpensive fix ....I'd go with moog personally
kazper413 is offline
post #15 of 22 Old 08-01-2019, 05:42 AM
Quoted: 9 Post(s)
Itll also be easy to find out if it is them, can un bolt one end of the end link and see if they move real easy or are kinda stiff...if it just flops around its shot, should move but need help doing so...can do this to both sides. Dont have to jack the truck up or anything. Leave the nut on the last few threads and rubber mallet the end link out of sway bar, or truck mount...hope this helps
post #16 of 22 Old 08-01-2019, 12:44 PM
Quoted: 8 Post(s)
Wheel bearing (needle bearings).
post #17 of 22 Old 08-01-2019, 04:53 PM
Quoted: 9 Post(s)
Hopefully when the mechanic checked the ball joints he checked the wheel bearings too...that is a possibility but would think you'd feel it a little more than just when you hit bumps
post #18 of 22 Old 08-02-2019, 09:03 PM
mustangea's Avatar
Quoted: 9 Post(s)
Garage
I agree with the above posts from tph1956 and kazper413......the swaybar links. all 3 of my Superdutys had them wear out and replacing them fix the clunking and also some rattling. Invest in a good pair though. My current rig has a set with greese fittings built in and they seem to be the most robust so far. I wouldn't skimp out with a cheap pair.
Keep us posted, dude.
2002 F-250 (gray on black)
1990 Bronco II
1994 Mustang GT
mustangea is offline
post #19 of 22 Old 08-05-2019, 04:27 AM Thread Starter
Quoted: 19 Post(s)
I replaced the sway bar links over the weekend and the noise is gone. Wow we’re they shot. Pics below.
ID:	721457   Click image for larger version
post #20 of 22 Old 08-06-2019, 06:23 PM
Quoted: 9 Post(s)
Glad to hear you found your problem!! Thanks for letting us know
bjblackout likes this.
