waiting for glow plugs ? - Page 2 - Ford Powerstroke Diesel Forum
post #11 of 19 Old 06-22-2019, 11:13 AM Thread Starter
Left Coast Geek's Avatar
Quoted: 137 Post(s)
Garage
Send a message via AIM to Left Coast Geek Send a message via MSN to Left Coast Geek Send a message via Yahoo to Left Coast Geek
ok, here's pages out of the 2002 diesel supplement that came with my F250...
2002 F250 Super Cab XLT longbed, white. stock except stereo and shell.
....old enough to know better....
Left Coast Geek is offline
post #12 of 19 Old 06-22-2019, 12:01 PM
Quoted: 461 Post(s)
Feedback Score: 3 reviews
That's interesting...
Who Knew there were so many variants to an '02 Cluster!
NoRalPh is offline
post #13 of 19 Old 06-22-2019, 12:56 PM
00t444e's Avatar
Quoted: 597 Post(s)
Originally Posted by greenskeeper View Post
On both my trucks, the WTS light coincides with the glow plugs being on at "key on". The WTS light goes out prior to the glow plugs turning off. That being said. The single best thing I ever did in regards to the glow plug system was to add an LED light on the dash wired to the hot side of the GPR as well as a "kill switch" breaking the ground from the PCM to the GPR. With this setup I know when the glow plugs are being energized by the PCM and can also over-ride the GPR when it's above 40F. So much less wear and tear on the glow plug system and batteries during the warmer months.
Not a bad idea, I have mine on a push button, I only have to use my glow plugs if it's in the 50s or below.
00 f250 ext. cab, lb, 4x4, 158,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #14 of 19 Old 06-26-2019, 03:41 PM
jerryabeach's Avatar
Originally Posted by NoRalPh View Post
Wow! That pic is from YOUR '02? 'Cause my '02, and even my '02 OM shows this on page 7. Not sure what you've got there...
In any case, despite whatever shape the icon might be, it still has NOTHING to do with GP function
I have the same light on my 2016 and according to the Diesel supplement for the owners manual, it is Glow Plug Pre-Heat. Instructions say to wait until the light goes off before starting. This is included with trucks that have the cold weather starting strategy.
For the OP, you only need to worry about this for cold weather starting.
jerryabeach is offline
post #15 of 19 Old 06-29-2019, 03:02 AM
Quoted: 77 Post(s)
Personally I just do what the wts light says even though I live in Savannah and in the dead of winter our lows are around 40. I figure the designers and engineers have a reason the wts is on. I notice it is on sometimes longer than others so the pcm is making some decisions that I am not aware of.
Sent from my Nexus 6P using Tapatalk
guitarnut is offline
post #16 of 19 Old 06-30-2019, 12:17 PM
00t444e's Avatar
Quoted: 597 Post(s)
Originally Posted by DaveP. View Post
That's an Econoline Cluster. If your truck is a pick-up, that is not the original cluster. hope you didn't pay a premium for "low mileage".
Nope, that's what a factory 02 cluster looks like.
00t444e is offline
post #17 of 19 Old 07-03-2019, 12:39 PM
Quoted: 17 Post(s)
What part of the world are you guys from? In the US, the cluster's switched to this style in mid model-year '01. All US 02s and 03s have the "new" style cluster with the digital odometer, trans temp gauge, and squiggly WTS light.
2000 ECLB 4x4 7.3L PSD - Converted from a beat up XL farm truck and frame off restored thanks to New England road salt
Cosmetic: 05 Harley front end, 11 tailgate, black sport full power interior, 05 dash with aux switches and brake controller
Performance: AFE intake, SPX billet compressor wheel, Turbomaster wastegate, blank pedestal & exhaust housing, MBRP 5" exhaust, PHP Hydra, gauges and CTS2
Audio: Sony XAV-AX5000, JBL Club speakers, fully sound deadened
Lt.Dan is offline
post #18 of 19 Old 07-03-2019, 01:26 PM
Quoted: 2 Post(s)
My 2002 usually need a few seconds when the temp was below 30.
sandmandjs is offline
post #19 of 19 Old 07-06-2019, 12:17 AM Thread Starter
Quoted: 137 Post(s)
Garage
heh, I helped someone move a brand new big Mercedes Sprinter camper... stuck wierd shaped key in ignition, click to Run, then twist to Start. huh, nothing happens. let go of key so it goes back to Run, and the engine goes ruh-ruh-ROOMMMMMMMMM and diesels away. too much tech for me. actually, that big beast was pretty easy to maneuver with good mirror sight lines.
