Brakes - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-20-2019, 09:04 AM Thread Starter
Brakes
Can anyone tell me how to trouble shoot the Brake booster on a 2001 f350 4x4 7.3l. I have a spongy pedal and it gets better when you pump it. I feel it’s with the booster or the abs pump. Any help appreciated.
post #2 of 3 Old 06-20-2019, 10:51 AM
00t444e's Avatar
Quoted: 611 Post(s)
A soft pedal is caused by air in the lines, a leak, or bad master cylinder. A bad brake booster would make the pedal harder to push.
00 f250 ext. cab, lb, 4x4, 158,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #3 of 3 Old 06-20-2019, 04:13 PM
Widowson2's Avatar
Quoted: 4 Post(s)
Power steering pump supplies hydro boost. If fluid is old and dirty it needs to be flushed. Cured my spongie pedal. Easy to do and there are videos out there on procedure. Just another thing for you to check.
Widowson2 is offline
