AC Issue - Page 2 - Ford Powerstroke Diesel Forum
post #11 of 13 Old 06-20-2019, 10:09 PM
GETFURIOUS's Avatar
Quoted: 223 Post(s)
Originally Posted by guitarnut View Post
Can you explain how to do it? My brand new AC will barely cool my extended cab unless I put it on max. It's 95 here in Savannah
TAKE A LOOK AT THIS VIDEO.....
GETFURIOUS is offline
post #12 of 13 Old 06-21-2019, 12:39 AM
Quoted: 46 Post(s)
Thanks furious!
Sent from my Nexus 6P using Tapatalk
guitarnut is offline
post #13 of 13 Old 06-21-2019, 10:36 AM
TripleStix's Avatar
Quoted: 16 Post(s)
I removed one of the washer or "shims" from mine a couple years ago and was within acceptable tolerance for gap, also made sure was able to cycle properly. Also cleaned the surface of the clutch plate w/ some QD electrical cleaner while I was looking at it.
If I remember right just turn ignition on, toggle the dial for air to ac mode and back off should be able to make out an audible click of the clutch engaging. Mine got to where I would have to tap it to engage... or hit a good bump on the road if it had cycled off. If it is engaging fine but still same symptoms I'd look deeper.
TripleStix is offline
