Slight Thud - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By BryanSR
post #1 of 9 Old 05-13-2019, 10:35 PM Thread Starter
Quoted: 9 Post(s)
Slight Thud
So I inherited a 2001 and am not sure what maintenance has been done over the years but it only has 108,000 miles on it. With that being said when going over decent sized bumps the front end makes a kind of thud sound. Also truck is a little bouncy when driving.
Could this be I need new shocks??
If so what brand do you suggest. Truck is not lifted.
bjblackout is offline
post #2 of 9 Old 05-14-2019, 12:28 AM
doubleslottedflaps's Avatar
Quoted: 149 Post(s)
factory stock shocks are bouncy even new ones. i put ford shocks on both my trucks recently and they bounce BUT the also give the smoothest ride. I have ridden in many ford superdutys over the years with all kinds of aftermarket shocks and i prefer the bouncy.
NOTNOW > 2001 F350 CCLB DRW SCHTICK SHHHIFTER
WONTON > 2002 F350 CCLB DRW OTTOMATIC
FTCOBRA > 2006 F350 CCLB DRW SCHTICK SHHHIFTER
doubleslottedflaps is offline
post #3 of 9 Old 05-15-2019, 04:20 AM
Billy231's Avatar
Quoted: 56 Post(s)
Garage
Sounds like sway bar link bushings. Common cause for that ďthudĒ sound when turning or hitting small bump.
As for shocks, many have used Bilstein which I also switched to and really enjoyed the difference.
Sent from my iPhone using Tapatalk
Billy231 is offline
post #4 of 9 Old 05-21-2019, 07:03 AM
Quoted: 16 Post(s)
My 02 was making the same noise, sway bar links fixed it.
Sent from my SM-J327P using Tapatalk
ToyMan likes this.
BryanSR is offline
post #5 of 9 Old 05-21-2019, 03:53 PM Thread Starter
Quoted: 9 Post(s)
For the price of them I am just going to order some and replace them and see if that fixes the sound I hear. Are the Dorman brand OK??
post #6 of 9 Old 05-22-2019, 08:15 PM
Billy231's Avatar
Quoted: 56 Post(s)
Garage
Slight Thud
For whatever reason these trucks eat bushings. Iím not a big fan of Dorman, especially wear n tear items like this. If not for me changing dynamics of front end,Iíd just go OEM, dealer/eBay/Rock auto.
I did a PMF shackle kit lift (2Ē) so I tried their link/bushing kit. Slightly pricey but was impressed with overall design and ability to grease them. Been a couple years and still holding up.
Billy231 is offline
post #7 of 9 Old 05-23-2019, 05:57 AM
For a thud i'd also be sure to check the lower shock bushings. They make a pretty good thud.
99 F250
160/0, HPx, FRx, 6637, 38r (coming soon)
bmwfilmax is offline
post #8 of 9 Old 05-23-2019, 11:54 AM
SuperCrutyPS's Avatar
Quoted: 568 Post(s)
Garage
Wouldn't hurt to check the ball joints. Most of the time, they'll clunk when turning, but while you're checking stuff.....
Darryl | Owner/Operator
Truck | 2001 F350 CCLB
5th Wheel |
Proud Veteran | US Navy - '76-'80 - Petty Officer 2nd Class (E5)
SuperCrutyPS is offline
post #9 of 9 Old 05-27-2019, 09:47 PM Thread Starter
Quoted: 9 Post(s)
Finally got around to checking the bushings and they look good do I didn't replace them at this time. As I was under there though the shocks look pretty old.
Similar Threads
Thread Thread Starter Forum Replies Last Post
Slight rough idle and stutter when revved Anthym 99-03 7.3L Powerstroke Problems 12 11-05-2017 09:42 AM
slight misfire when engine starts to warm up? 97Powerstroke? 94-98 7.3L Problem Forum 4 01-17-2017 03:19 PM
'08 F250 6.4L - White smoke at start of regen with slight loss of coolant ccf250 6.4L Problems Forum 8 09-22-2016 07:26 PM
Thud on take-off 00f250 99-03 7.3 Drivetrain Problems 9 01-31-2007 01:26 PM
