Hissing Sound ? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 05-12-2019, 10:50 AM Thread Starter
Quoted: 15 Post(s)
Hissing Sound ?
Let me start like I start all my post. I am new to the diesel world so I am sorry of this is a stupid question.
I have an 01 and when accelerating and holding the gas down under load ( like a hill pull or incline where I am accelerating) I get a hissing sound from under the hood. It’s pretty loud and can hear it over the radio if it’s on. It stops when I release gas pedal. My truck does have a cold air filter kit, not sure of the brand. Is this hissing normal and do these trucks have a blow off valve for the turbos and would that be what I am hearing. Also when the truck shift through gears normally I get the noise of hissing or released air when the truck switches up to the next gear.
I am definitely not complaining about the noise because it sounds kind of good like a blow off valve but weird that it makes the noise under heavy acceleration also. Just want to make sure what I am hearing is normal.
Truck has a hydra chip installed but it was on there when I got the truck.
Any help would be appreciated.
bjblackout is offline
post #2 of 15 Old 05-12-2019, 11:37 AM
DesertDiesel's Avatar
Quoted: 66 Post(s)
That's the turbo spooling.
DesertDiesel is offline
post #3 of 15 Old 05-12-2019, 04:06 PM Thread Starter
Quoted: 15 Post(s)
Even after I let off the gas? Also if I accelerate and stay in the gas the swooshing sound will stay at a constant tone and loud.
Like I said after the truck shifts through the gears it sounds like air is being released as soon as it goes into the next gear.
post #4 of 15 Old 05-12-2019, 04:12 PM
7.3_TurboDiesel's Avatar
Quoted: 91 Post(s)
That is your wastegate opening. When you let off the gas pedal, the pressure your turbo has built up has to go somewhere, so the wastegate opens to allow it to dissipate
Sent from my iPhone using Tapatalk
7.3_TurboDiesel is offline
post #5 of 15 Old 05-12-2019, 05:32 PM Thread Starter
Quoted: 15 Post(s)
Does the wastegate open while you have the accelerator down also. If I accelerate hard or have boost over 10 or so I hear the air swooshing sound the whole time I am accelerating.
post #6 of 15 Old 05-20-2019, 07:05 AM
wickettoby1's Avatar
Quoted: 3 Post(s)
The wastegate is responsible for diverting exhaust pressure from the turbine housing on the turbo to the exhaust stream. At full boogie the wastegate could be partially opening which will keep the turbine drive pressure at a safe level. People have been known to adjust the wastegate rod tighter which will consequently require more exhaust pressure to open the wastegate and cause elevated boost levels.
wickettoby1 is offline
post #7 of 15 Old 05-20-2019, 07:07 AM
Quoted: 3 Post(s)
Blackout
If your only making 10lbs of boost at WOT you have other issues to work through also.
post #8 of 15 Old 05-20-2019, 07:12 AM
Quoted: 3 Post(s)
What your referring to is a blow off valve which our trucks don't have from the factory.
post #9 of 15 Old 05-20-2019, 08:25 AM
ChrisSki's Avatar
Quoted: 548 Post(s)
I recently made some boost leak pressure detectors for my 6.0. There's a couple of videos, but I have a 6 gallon compressor with 1/4" air hose. I used:
-4" or 3" rubber pipe caps. They come with a worm clamp to tighten them tightly on the pipe. They're available at home depot and size depends on whatever pipe you're pressurizing.
-1/4" quick disconnect for the air hose. I inserted the male end through a hole I drilled in the rubber pipe cap.
- 2" fender washer with a half inch hole. I got two of these. One went on the the inside of the rubber cap, the other on the outside. This kept the Quick disconnect from blowing out.
- A 3/8 to 1/4 NPT Reducer. Went inside and acted as the washer to secure the quick disconnect on.
That took about $20 to make.
For the Gauge:
-I also bought a 1 foot long Male threaded, 1/4" air hose
-I screwed this into a 1/4" NPT Tee that had two male ends and a one female end.
-On one side, I had a 1/4" NPT air valve to turn on and off.
-I attached a 1/4" NPT Quick disconnect, one male and one female to two sides. (I needed a Female to FEmale 1/4" NPT attachment to attach the QD to the tee.
-I put a 1/4 NPT 0-30 PSI gauge on the female part of the TEE.
That cost about an additional $30 to make.
Boost leak detectors are available from around $75, and mine cost $50. The commercial one will hold more PSI, mine blows off on 5-10 PSI. I've put up to 45 PSI on the commercial one, but the commercial one usually blows a metal plug out around 10 to 15 PSI, which is quite dangerous. The metal plug is basically a 4" round plug inside a CAC boot. That's come within inches of my face when it blew out. I don't like that idea at all.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #10 of 15 Old 05-21-2019, 01:19 AM Thread Starter
Quoted: 15 Post(s)
But they have some type of waste gate factory installed?? Someway for the pressure to be expelled??
Similar Threads
Thread Thread Starter Forum Replies Last Post
Is this engine sound normal? aheich86 General 6.7 Discussion (2011-2016) 5 04-28-2019 09:40 AM
Hissing sound during cruising speeds Elmo81 99-03 7.3L General Discussion 13 12-25-2018 09:23 PM
2006 f350 Odd engine sound. SLJMGARY 6.0L Problems Forum 2 05-02-2018 03:00 PM
whirring/whining sound in low rpm Pup444 94-98 7.3L Problem Forum 5 01-20-2018 05:33 PM
6.0L fuel filter housing hissing sound Tonelli11 6.0 Motor problems 2 09-09-2016 06:32 PM
