Fumoto drain Valve - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By JustinOOO9
  • 1 Post By Pmedic920
post #1 of 10 Old 04-19-2019, 09:57 AM Thread Starter
Quoted: 18 Post(s)
Fumoto drain Valve
I am looking at getting a Fumoto drain valve, should you put pipe thread tape on the threads or JB Weld it in the oil pan?
stroupdr is offline
post #2 of 10 Old 04-19-2019, 10:00 AM
TripleStix's Avatar
Quoted: 16 Post(s)
Neither. If I remember correctly, it had a fiber washer or something to that effect included on it to seal it. Mine works great.
Sent from my iPhone using Tapatalk
TripleStix is offline
post #3 of 10 Old 04-19-2019, 10:06 AM
JustinOOO9's Avatar
Quoted: 1517 Post(s)
Garage
Feedback Score: 3 reviews
No thread sealant or tape needed. I've had mine on four three years now. It does slow down the drain process but letting it warm up before hand and zero drops anywhere else but the drain pan made it worth the extra couple minutes. I got the one with the short nipple too. huge help.
Some have cautioned it could snag on something. If that thing gets snagged/ripped off you're already in huge trouble due to where its located in relation to the steering components, front axel and height etc. Benn through -20 in North Idaho and 115+ in CA and just love the mess free ability now.
TripleStix likes this.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
Justin
JustinOOO9 is offline
post #4 of 10 Old 04-19-2019, 10:24 AM
TripleStix's Avatar
Quoted: 16 Post(s)
+1 on the snag concern. I donít know which nipple you got, I think there was a shorter version available from the one I got, think mine is 1Ē. Regardless, if I did hit that, I too expect I would have bigger problems to address.
post #5 of 10 Old 04-20-2019, 07:15 AM
RJC2's Avatar
Quoted: 690 Post(s)
I agree with the others, no sealant is needed, however, if you do elect to use it be sure not to use the white Teflon tape as its not rated for use with oil.
I just bought another 7.3 yesterday and am buying Fumoto to go on it. You'll thank yourself every time you crawl underneath it to change the oil.
2017 F350 CCSB King Ranch Ultimate 6.7
2002 F250 ECLB, XLT, 7.3 PSD, 4X4, Auto, TW 6pos. Tuner, 4" SS Exhaust, Britebox, EZ Down tailgate assist, Rear Air Bags, 6.0 trans cooler, Wicked Wheel 2, Corey's HPX, Dieselsite Water pump w/built-in filter, 203 degree thermostat, Max A/C assist, Oil drain valve, Non EBV pedestal & Flange, S.S. bellowed up pipes, Dieselsite Lifetime Rad. hoses & Intercooler hoses, New oil cooler
RJC2 is offline
post #6 of 10 Old 07-24-2019, 09:06 AM
Pmedic920's Avatar
Quoted: 5 Post(s)
Fumoto drain Valve
Im sure your way past needing any more info but I've got to get my post count up.
I use FV on my Jeep, mainly to control the mess (complete aftermarket skid system). I love the product. as others have said, don't use sealant, it shouldn't be needed.
I do, and highly recommend that you clean the original drain plug and toss it in your tool/glove box to always have available. in the event that something does happen to the valve, oil is easy to come by, drain plug may not be.
Edit: for pix.
On my Jeep, the value is somewhat vulnerable, so I slapped a piece of scrap over the access hole to protect it a bit more.
voodooridr likes this.
Pmedic920 is offline
post #7 of 10 Old 07-24-2019, 09:52 AM
retaliashun's Avatar
Quoted: 63 Post(s)
Garage
I took mine off and went back to regular drain plug. Always seemed like it wanted to slow leak oil. The lever never felt like it wanted to seat and lock in place, there was always a little play in the spring action when locked in place.
retaliashun is online now
post #8 of 10 Old 07-24-2019, 03:01 PM
hansel's Avatar
Quoted: 339 Post(s)
Just screw it in nice and snug
hansel is offline
post #9 of 10 Old 07-24-2019, 03:23 PM
Quoted: 18 Post(s)
I've had mine on since between 2010-2012 and never had an issue. Mine is like the one Hansel posted but does not have the extra security by the valve lever, no nipple either. I will agree that it doesn't drain quite as fast but not a big deal to me. My truck is tall enough that i slide a 5gal bucket under it and slide the lever over....do other things while it's draining. I have no regrets in purchasing. I bought mine for the ease of draining and no mess.
INFRNL is offline
post #10 of 10 Old 07-24-2019, 05:33 PM
Corey@CNCFAB's Avatar
Quoted: 1389 Post(s)
Feedback Score: 4 reviews
I like mine too. Snag issue is non-existent. If you have something hit the Fumoto, then that will mean that your front axle took a pretty hard hit.
[SIZE="3"]For all your ford powerstroke needs. If you dont see what you are looking for on the website, please use the contact page and shoot us a message or
Part numbers will help alot too if they are not on our site.
Similar Threads
Thread Thread Starter Forum Replies Last Post
EZ Drain Valve in place of Block Drain Plug Gringo_Tex General 6.0L Discussion 14 01-03-2019 06:37 AM
oil drain valve ct03911 General 6.7 Discussion (2017-2019) 23 03-22-2018 05:13 PM
Fumoto Oil Drain Leak USAF93 General 6.0L Discussion 45 12-25-2016 02:14 AM
fuel drain releif valve / fuel leak Brian 99-03 7.3 Motor Problems 0 09-14-2006 04:05 PM
