Small Oil Leak - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-09-2019, 11:29 PM Thread Starter
Quoted: 20 Post(s)
Small Oil Leak
Just inherited a 2001 F250 and when I park it and come out a day or so later I have a small oil spot on the street about the size if a dollar bill. Where should I start looking to find this oil leak. I am not a mechanic by any means but like to try to fix things if I can.
Any help steering me in the right direction is appreciated.
Truck has 108,000 on the odometer. (7.3L
bjblackout is offline
post #2 of 3 Old 04-10-2019, 05:54 AM
mike_hurd2000's Avatar
Quoted: 28 Post(s)
The first thing I would do is take a look in the top of the engine if you canít pin point the leak give it a good clean. your height pressure oil pump is right under the fuel bowl. It has lines coming from it to each head check those and several plugs on the pump on the back. Check the fuel bowl there a drain valve it is yellow it will leak as well. Check the turbo it can leak were it mounts to the block there is also a rod coming out of the pedestal attached to the turbo that can leak as well. A few other places is passenger side of oil pan were the dipstick is to check oil level right by the starter can leak.
Sent from my iPhone using Tapatalk
mike_hurd2000 is offline
post #3 of 3 Old 04-10-2019, 07:53 AM
JustinOOO9's Avatar
Quoted: 1706 Post(s)
Garage
Feedback Score: 3 reviews
Welcome to the org. give this a good read it covers 99% of the most common leaks and how to fix them for the 99-03 7.3l.
https://deadheaddiesel.com/7.3-power...mon-oil-leaks/
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Most common sources of small coolant leak AMG1978 General 6.7 Discussion (2011-2016) 20 02-24-2019 05:53 AM
Massive oil leak from passenger's rear of engine Redlineauto 99-03 7.3 Motor Problems 23 09-18-2018 08:27 PM
Intermittent heat, low coolant and small leak cjf43 6.4L Problems Forum 3 01-11-2018 12:56 PM
Small Coolant Leak STL06f250 6.0 Motor problems 3 03-17-2017 08:31 PM
small oil leak around turbo Brian 99-03 7.3 Motor Problems 3 02-15-2006 02:34 PM
