Ball joint - Page 2 - Ford Powerstroke Diesel Forum
 6Likes
post #11 of 15 Old 03-22-2019, 06:27 AM
ZMANN's Avatar
Quoted: 3736 Post(s)
Spicer is OEM
I am with Jake
I used to look for greasable or even add Zerks to non servicable units
but the sealed for life stuff has been easier and just as long lasting in my experiance between siiliar parts
voodooridr, rappy700 and Jake6.0 like this.
6.0 flush pdf
ZMANN is offline
post #12 of 15 Old 03-22-2019, 09:57 AM
doubleslottedflaps's Avatar
Quoted: 144 Post(s)
my 06 has over 100,000 on the Moog BJ's I put in. My 02 has 133,000 on the original and my 01 has 130,000 on the original. For the cheap price of Moog and the miles they last I cant complain. The plus side with greasable is you can always have fresh moist grease in them and keep dirt and moisture pushed out. when I worked as a mechanic my specialty was front suspension and steering. I rebuilt a whole lotta front ends and aligned them on the Hunter. I worked for a shop for a short time that had a John Bean mirror aligner. That was a huge pos.
NOTNOW > 2001 F350 CCLB DRW SCHTICK SHHHIFTER
WONTON > 2002 F350 CCLB DRW OTTOMATIC
FTCOBRA > 2006 F350 CCLB DRW SCHTICK SHHHIFTER
doubleslottedflaps is offline
post #13 of 15 Old 03-28-2019, 12:28 AM
Quoted: 2 Post(s)
I went with OEM non-greasable. The originals (‘03 F350 SRW 4x4) lasted over 138,000...lubed for life ball joints and u-joints are stronger IMH albeit not a mechanical engineering O...
larrygraham76 is offline
post #14 of 15 Old 03-28-2019, 06:46 AM
roverjosh's Avatar
Quoted: 36 Post(s)
Garage
I have a 6.7 but lets face it, they are basically the same axle (I think). I went Spicer. Non-serviceable.
Moog used to be great but in my research a month ago the concern with Moog is the stuff that is being produced now may not be of the same quality as the stuff from a few years ago so take that with a grain of salt.
You can't go wrong with Spicer, cuz its OEM. Mine went 166k miles. Probably could have squeezed another 10k out of them but I had to do U-joints and tie rods so since it was apart, I did them all anyway.
Hope that helps.
When it comes to mechanics, everything I know is from either breaking it or watching someone else do the same. Then I had to fix it....Is that bad?
Murphy's Law: "things will go wrong in any given situation, if you give them a chance."
roverjosh is offline
post #15 of 15 Old 03-28-2019, 08:43 AM
00t444e's Avatar
Quoted: 512 Post(s)
Spicer is what I recommend, Moog isn't worth the money, they started going downhill 4-5 years ago.
00 f250 ext. cab, lb, 4x4, 158,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Is my ball joint seated enough? EskimoPie General 6.7 Discussion (2011-2016) 3 09-12-2017 12:03 PM
2006 F350 4 x 4 - Ball Joint Time PA_Robert Suspension & Steering 29 02-15-2017 08:53 AM
Track Bar Ball Joint Keeps Failing After Lift charbaugh Suspension & Steering 48 02-14-2017 06:34 PM
2007 F250 track bar ball joint install. FordPSD6.0 Suspension & Steering 3 11-29-2016 03:56 PM
superduty ball joint replacement mschn99 General Tech, Maintenance, and Mod info 0 03-24-2006 04:50 PM
