speedometer calibration, and CA legal programmer/chip? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 03-09-2019, 10:25 AM Thread Starter
Quoted: 8 Post(s)
My 2000 is basically stock except for a home-made intake tube with a big air filter, and 4" exhaust with no catalytic converter and not much of a muffler. It is a CA factory non-catalyst vehicle. I'm putting 315 tires and I'd like to have the speedometer read closer to correct.
I also wouldn't mind having more power as well, but I'm not looking to race this thing or blow smoke everywhere, or tow huge loads.
The CA legal products that I see are the somewhat generic tunes from what I gather, like superchips, diablo, banks, edge, and so on. I realize these aren't going to be as good as an actual custom tune. I'd be fine with that, if they at least noticably wake the truck up a bit.
For someone who wants to comply with the local laws, are these at all noticeably better than stock?
I have a manual 6 speed transmission, if that makes any difference.
2000 f250 Superduty, 7.3, 4x4, regular cab, long bed, 6 speed manual, 315/70/17 Dick Cepek tires.
error404 is offline
post #2 of 10 Old 03-09-2019, 11:36 AM
00t444e's Avatar
Quoted: 608 Post(s)
Of the ones mentioned Edge would probably be the best option. Also I would't worry about it being legal in CA because all you have to do is program it back to stock for testing.
00 f250 ext. cab, lb, 4x4, 158,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #3 of 10 Old 03-09-2019, 12:05 PM
SuperCrutyPS's Avatar
Quoted: 647 Post(s)
Garage
I have an '01 F350 (see sig below) I live in CA. Pretty much the same set up as you - K&N cone intake, 4" turbo-back exhaust (factory non-catalyst) with a "pass-through' muffler.
I have an older Hypertech Power Programmer III (41040). It has three "canned" tunes, ability to adjust for tire size & reads/clears DTCs. (Different year models had different PNs) I actually have a letter from Hypertech saying it's CARB-compliant.
The different tunes to make a difference over stock. Like you, I wasn't looking to turn a 4 1/2 ton truck into a hot rod, these wake it up pretty well. When I went up to 285/75R16s, I was able to adjust the tire size to correct the speedo. I even compared it to GPS to see it was right.
Darryl | Owner/Operator
Truck | 2001 F350 7.3L CCLB |
5th Wheel |
Proud US Navy Veteran | '76-'80 -
- 'Gator Navy
SuperCrutyPS is offline
post #4 of 10 Old 03-09-2019, 01:33 PM
doubleslottedflaps's Avatar
Quoted: 190 Post(s)
The ford dealer can reprogram the speedo. Get a hydrachip and pull it out on smog inspection day. the 4" exhaust is not an issue. I have a cali approved AFE intake. I live in cali and have 3 trucks.
NOTNOW > 2001 F350 CCLB DRW SCHTICK SHHHIFTER
WONTON > 2002 F350 CCLB DRW OTTOMATIC
FTCOBRA > 2006 F350 CCLB DRW SCHTICK SHHHIFTER
doubleslottedflaps is offline
post #5 of 10 Old 03-09-2019, 03:02 PM
SC-Surfer's Avatar
Quoted: 139 Post(s)
Garage
Yep. AFe intake, 4 cat back and a hydra. No issues smogging just put it on stock tune. All good.
Sent from my iPhone using Tapatalk Pro
2002 F350, 7.3l, CCLB, WW2, HPOP crossover, Coolant bypass filter, ATF inline filter, 4" exhaust, afe intake with AIS, 4" lift, 35's, Hellwig Big Wig F/R, Rancho900XLs, Firestone bags, PHP Hydra.
SC-Surfer is offline
post #6 of 10 Old 03-09-2019, 03:44 PM
Mike Gs's Avatar
Quoted: 103 Post(s)
You can change the revs per mile with Forscan nearly for free. Need Forescan, a wireless obd connector ($20) and need to get the temporary license from the forum.
Mike Gs is offline
post #7 of 10 Old 03-10-2019, 06:39 PM
Quoted: 25 Post(s)
Yup, here is a good how to: https://www.ford-trucks.com/forums/1...er-change.html
akcooper9 is offline
post #8 of 10 Old 03-11-2019, 08:21 AM Thread Starter
Quoted: 8 Post(s)
thanks for the replies fellas :-)
Yes, it does pass smog with zero issues with the intake and exhaust. I'd like to keep it that way :-)
error404 is offline
post #9 of 10 Old 03-11-2019, 08:38 AM
JustinOOO9's Avatar
Quoted: 1670 Post(s)
Garage
Feedback Score: 3 reviews
WElcome to the org!
You having the 6 speed opens up tuning a lot. the majority of the BIG issues with Edge, banks, superchips etc was the shifting with autos. That and a little less power then tunes from say a custom chip etc...
Since you only have to smog every other year. You could easily get by with a hydra chip. It plugs into your ecm directly vs the flash programmer that plug into your OBDII port. Me personally I would try to find an older edger evo model 15000 (looks like a gamboy old school) or get a php hydra chip from one of the vendors like @[email protected]
I recommend the old edge evo1 because the programmer for that chip was Bill from powerhungry performance who designed the hydra chip which is the gold standard for 7.3l owners but since you control shifting with the 6spd you may save some coin with the edge flash programmer etc.
CA smog is not hard on the 7.3L at all. If you are a man of principle/conscious edge and superchips have C.A.R.B. approved programmers but the hydra or an old edge evo will more than bring a smile to your face.
ALso I second the forscan method for adjusting the speedo/odometer.
download forscan on a pc laptop spend $20 on a obd2 to usb adapter cable and make an account on the forscan.org forum to request the temporary extended license and follow the link cooper put to adjust. Did mine month or so ago and many others before me.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is offline
post #10 of 10 Old 03-14-2019, 09:13 PM Thread Starter
Quoted: 8 Post(s)
I picked up an Edge EvoHT2, plenty easy enough to change the tire size, and I'm happy with the engine tuning. I do notice a slight haze out the exhaust when I romp on it in 4th-6th gear. I'm not thrilled about that, but it's rare that I go full throttle, so I'm ok with it. Normal driving is very nice, and the larger tires actually seem to make the gear ratios in the transmission feel more natural. Still don't ever use 1st gear on the street, but even 3rd gear remains ok to start out on a flat stop, just have to give it a slight bit of throttle.
My first problem with the new tires/wheels is that the wheel weights fell off. All of them. Every. Single. One... before I even bolted the wheels onto the axles. I grabbed the wheels/tires out of the bed of the truck to bolt them on, and found 5 strips of weights just laying in the bed. WTF? hah! I'm guessing the monkeys didn't wipe off and clean the inner wheel before they stuck the weights on. I've had stick-on weights on many vehicles that never fell off before, even my rock crawler jeep never lost wheel weights... :-\
error404 is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Speedometer calibration Ammo9000 General 6.7 Discussion (2017-2019) 6 02-28-2019 06:45 AM
Speedometer Calibration? Horizon122 99-03 7.3L General Discussion 5 10-30-2018 11:19 AM
Speedometer Calibration chrisoneill88 General 6.7 Discussion (2017-2019) 19 07-24-2018 07:31 PM
Speedometer Calibration Curt Riley General 6.4L Discussion 2 06-24-2018 09:51 PM
