Cost of 33-34" tires - Ford Powerstroke Diesel Forum
 4Likes
  • 1 Post By SuperCrutyPS
  • 2 Post By Discount Tire
  • 1 Post By sbluke55
post #1 of 9 Old 01-06-2019, 01:48 PM Thread Starter
Quoted: 7 Post(s)
I currently have 265/75r16 tires on my 01 SD with 3.73 gears. I want to get a larger tire basically for better looks. What are the real world consequences of going with a 33 or a 34 inch tire? I was thinking 285/75r17 or 285/75r16. I plan on towing a travel trailer here in a couple years so factor that into your assessment. Thanks for any advice.
aheich86 is offline
post #2 of 9 Old 01-06-2019, 02:12 PM
SuperCrutyPS's Avatar
Quoted: 625 Post(s)
Garage
I went up to 285/75r16 from 265s (Toyo Open Country AT2). They've been great. I do have a Hypertech programmer that allows for tire size adjustment so the speedo is correct. The only issue I have: I have Duraflap mudflaps on my truck. The left front tire rubs that flap @ hard left.
I think I paid ~$1300-ish for my tires. You can check with our tire Supprting Vendor, @Discount Tire . He could give you some pointers.
jokester00 likes this.
Darryl | Owner/Operator
Truck | 2001 F350 7.3L CCLB
5th Wheel |
Proud US Navy Veteran | '76-'80 - Petty Officer 2nd Class (E5) - U.S.S. Point Defiance (LSD-31) - 'Gator Navy
SuperCrutyPS is offline
post #3 of 9 Old 01-06-2019, 02:17 PM
JustinOOO9's Avatar
Quoted: 1628 Post(s)
Garage
Feedback Score: 3 reviews
I paid $1050 and some change for my 285/75R16s from America’s tire in Chico in 2017. You’re gonna be paying over 1,000 for a quality tire. Mine had two promotions going on otherwise it would have been around $1300.
Bfgoodrich, Cooper, Falken, Goodyear, Toyo, any big name tire should work.
Stay away from cheaper tires just not with the hassle usually.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is offline
post #4 of 9 Old 01-07-2019, 02:41 AM
Quoted: 4 Post(s)
I’m going with kenda klevers my bro in-law and a couple of buddy’s all got 50000 plus out of them and they are 10 ply... I priced it at 900ish for all six plus mount & balance
J_richmond09 is offline
post #5 of 9 Old 01-07-2019, 05:51 AM
Discount Tire's Avatar
Quoted: 34 Post(s)
Thank you for the referral, SuperCrutyPS!
As mentioned, the ODO and speedometer will be off but you should be able to calibrate for this. Also, larger tires tend to weigh more and if you go wider too you'll be increasing rolling resistance so fuel economy may be slightly impacted.
285/75R-16 is very common, though, and the tire selection is pretty vast. Just keep in mind that 285/75R-16 tires on the O.E. 7-inch wide wheels will "flex" a bit more when compared to stock so handling will feel different.
Heavy_GD and jokester00 like this.
Low Prices! More Choices! Trusted Experts!
At The Store:
To Your Door:
Useful Links:
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Discount Tire is offline
post #6 of 9 Old 01-10-2019, 09:46 AM Thread Starter
Quoted: 7 Post(s)
Hanks for the info! I have been mulling this over for a few days. Do you think a 285/75/17 would be too much for stock gearing (3.73) ?
Sent from my iPhone using Tapatalk
aheich86 is offline
post #7 of 9 Old 01-10-2019, 09:53 AM
JustinOOO9's Avatar
Garage
not even an issue by the slightest. The 285s are only a couple inches taller and strong inch or 2 wider. no issue for a diesel with 3:73s. your odemeter will be off jut a tad because a taller tire will have less revolutions per mile. my stock was a 265/75r16 and I have to multiple my odom by 1.038 to get the correct mpg.
I learned that forescan a free software for computers update came out and you can reprogram the odometer on the 7.3ls now so gonna do that this weekend.
post #8 of 9 Old 01-10-2019, 10:57 AM
Quoted: 34 Post(s)
I'm not a gear guru but I know a lot of guys here run larger tires up to 35" without issue.
As for the 285/75R-17, depending on the wheel dimensions you may have rubbing. 285/70R-17 would be another option and it maintains the same dimensions as 285/75R-16.
At The Store:
To Your Door:
Useful Links:
post #9 of 9 Old 01-10-2019, 12:16 PM
sbluke55's Avatar
Quoted: 892 Post(s)
Garage
I run 37Ē with 3:73 gears. Itís not awesome but it works. You wonít have any issues running 285ís.
ToyMan likes this.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
